Author Topic: Fog Lights  (Read 6863 times)
Big_Roger
  • Southampton
Fog Lights
« on: 17 January 2008, 16:42:32 »
Hi All
Can any one tell me if I should have any warning lights indicating when the front or rear fog lamps are switched on. (push switches underneath headlamp rotary switch)
I don't seem to have any, but I thought it was a requirement to have a warning light to say when rear fog lights are on.
Also, when I pull on the headlamp switch knob it clicks out. I can't see anything, but is this switching something on or off.
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
Re: Fog Lights
« Reply #1 on: 17 January 2008, 16:45:59 »
Hi All
Roger
You should have a warning lap on the dash, mine are in the bottom corners of the speedo (but your face lift is slightly different from my mini face lift.)
Pulling the light switch out should turn on your front courtesy lamps -
« Last Edit: 17 January 2008, 16:46:43 by Andy_B »
Re: Fog Lights
« Reply #2 on: 17 January 2008, 16:50:39 »
Post 98 cars have warning lights below speedo. Pre 98 have lights on the actual switches.
Re: Fog Lights
« Reply #3 on: 17 January 2008, 17:01:10 »
.. and it is a requirement to have one. Not sure you'd fail an MOT for it, but I was pulled up for not having one on the kit car at SVA (that was another hurried bodge in the test centre car park!)
Big_Roger
  • Southampton
Re: Fog Lights
« Reply #4 on: 17 January 2008, 17:01:28 »
Thanks folks, looks like it is a dash out job for weekend.
Roger
Re: Fog Lights
« Reply #5 on: 18 January 2008, 08:48:03 »
You will fail the MOT.....my old Nova did when the bulb failed in the switch.
« Last Edit: 18 January 2008, 10:21:52 by Mark »
spaceraceuk
  • Ipswich, UK
Re: Fog Lights
« Reply #6 on: 18 January 2008, 10:11:46 »
on the facelift, are the actual switches backlit? mine aren't and it's very hard to find them when driving in the dark. if they are meant to be backlit I guess you just pop the switch unit out and replace right?
- spacerace -
Re: Fog Lights
« Reply #7 on: 18 January 2008, 10:22:35 »
Your instrument panel.....are any of the readings in blue (i.e. Km's)
spaceraceuk
  • Ipswich, UK
Re: Fog Lights
« Reply #8 on: 18 January 2008, 10:34:33 »
can't think now. have to check but no I think it's all orange backlit. does it make a difference?
- spacerace -
Re: Fog Lights
« Reply #9 on: 18 January 2008, 10:44:48 »
And yours is a facelift car (i.e. mid1999 or later)?
If so, the Km reading from memory is in blue if the correct instrument panel is fitted, just considering that maybe its been swapped for an earlier version.
Re: Fog Lights
« Reply #10 on: 18 January 2008, 14:44:01 »
The panels without the fog light indicators are the pre minifacelift ones, which aren't electrically compatible iirc  :-/
spaceraceuk
  • Ipswich, UK
Re: Fog Lights
« Reply #11 on: 18 January 2008, 18:29:19 »
sorry, I was asking if the actual switches were backlit - i.e. light up in the dark, not the visual confirmations on the dash which work fine.
it is definitely facelift.
- spacerace -
RichardH
  • Ireland
Re: Fog Lights
« Reply #12 on: 18 January 2008, 20:44:09 »
Yes, once you turn on the lights in your car, then the foglight switches should be backlit.
Re: Fog Lights
« Reply #13 on: 18 January 2008, 21:04:18 »
Ahhhh....post highjack!
Yes they aer backlit but its by two LEDS in parralel with a single series resistor and if one fails the other follows soon after.....
So I suspect you will find two knackered LEDS in the switch.
spaceraceuk
  • Ipswich, UK
Re: Fog Lights
« Reply #14 on: 18 January 2008, 23:03:09 »
guilty, sorry! are they replaceable without a degree in electronics?
- spacerace -
