Author Topic: Coolant level Sensor  (Read 3338 times)
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« on: 03 February 2008, 19:08:59 »
Silly question...
I think the coolant level sensor is playing up on my V6, I would of though the sensor would be on the header tank but I can't see it, am I looking in the wrong place ?
Re: Coolant level Sensor
« Reply #1 on: 03 February 2008, 19:10:02 »
its underneath the header tank
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #2 on: 03 February 2008, 19:13:57 »
ah, I'll give it a look in the morning
What it's doing is every so often it will flash up "Check Coolant level" this stays on for about 2 mins then clears its self, only done it 3 times in the last 500 miles, but the coolant level is as it should, would this point to a dodgy sensore or some think else to look at ?
« Reply #3 on: 03 February 2008, 19:39:17 »
there is a float sensor in the tank, make sure that moves ok.
There is a metal clip on the outside edge of the tank, take that off. (with a flat end screwdriver)
Then just slide the tank out... don't pull it too far as there is a leccy connector underneath.
« Reply #4 on: 03 February 2008, 19:40:33 »
i assume the level in the tank stays the same, you never had to top it up?
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #5 on: 03 February 2008, 19:47:14 »
No, it's been as it should, though going to drop it tomorrow and stick some anti fresh anti freeze in, service history is all nice but I prefere to know it's been done if you follow my drift, same with the cam belt, Thats next weekend's mission
« Reply #6 on: 03 February 2008, 20:25:22 »
could not agree more. Keep anti-freeze in there all year around. Nice 50/50 mix.
Make sure you change the tensioners along with the cam belt, and do the waterpump at the same time  :y
« Reply #7 on: 03 February 2008, 20:49:46 »
Need to test if my repair method has worked next time I drop coolant from tractor.
« Reply #8 on: 04 February 2008, 10:25:38 »
Need to test if my repair method has worked .....
Which was ..... ?  :-?  :y
I soaked mine in a slightly caustic solution , which helped a lot in keeping the display happy. I replaced the tank in the end when I swapped to red anti-freeze cos it looked a lot nicer. ;)  :y  :y
