Author Topic: parking light  (Read 4051 times)
zippo
  • manchester
parking light
« on: 02 February 2008, 21:33:59 »
should a cd face lift have parking lights ? :-/
Re: parking light
« Reply #1 on: 02 February 2008, 22:35:58 »
Pretty certain they all do.
switch on indictator on the side you wish parking light on BEFORE switching off ign
Re: parking light
« Reply #2 on: 02 February 2008, 23:07:45 »
Without going out in the cold I don't think it makes a difference when you switch the indicator.
My 73 Cortina used to do this too, can't remember about my Cav coupe or Manta
« Last Edit: 02 February 2008, 23:08:23 by Andy_B »
Re: parking light
« Reply #3 on: 03 February 2008, 00:26:16 »
Does make a difference, and iirc, you need to turn on ign and cancel indicator to switch off.
uktigger
  • Blackpool, Lancs
    • 2003 2.2 Omega CD
Re: parking light
« Reply #4 on: 03 February 2008, 17:07:23 »
Page 15 in my manual says:
Starter Switch to OFF
Light Switch to OFF
Remove Key
Move Turn Signal Lever Up Or Down
Re: parking light
« Reply #5 on: 04 February 2008, 04:16:48 »
Oh no it doesn't!  ;) I've just had a look, the respective side light will light when the indicator is moved while the keys are in my grubby paws.  :y
zippo
  • manchester
Re: parking light
« Reply #6 on: 04 February 2008, 06:27:30 »
i forgot all about the park light so Ive just nipped out and tried it . No keys in the ignition, indicator stalk up a click, park light works but it wont turn off without the power being turned on
Result
thanks lads
Re: parking light
« Reply #7 on: 04 February 2008, 10:36:46 »
Result
thanks lads
I was nearly right, just got it arse about face...
Re: parking light
« Reply #8 on: 04 February 2008, 10:52:15 »
Pre face lift cars must be different then!  :)
uktigger
  • Blackpool, Lancs
    • 2003 2.2 Omega CD
Re: parking light
« Reply #9 on: 05 February 2008, 21:47:05 »
They must be, as i tried mine today.
They switched on AND off without the key,
also giving me the lights on alarm when i opened the drivers door.
Re: parking light
« Reply #10 on: 05 February 2008, 23:33:13 »
Yours is the same as Zippo's car.  :-?
The only difference in opperation between yours & mine is that I don't get the lights on buzzer
