Author Topic: Keyfob switches - sourcing new ones  (Read 3502 times)
Martin_1962
« on: 05 February 2008, 19:53:04 »
Does anyone know where I can buy some suitable new switches from?
Megamos appears to be a French component resellers. RS have none suitable nor do Maplins
Thanks
    • 530D M Sport, 330i Coupe
Re: Keyfob switches - sourcing new ones
« Reply #1 on: 05 February 2008, 20:05:42 »
Have you tried CPC / Farnell. I have an account with them if you don't want to register.
Martin_1962
« Reply #2 on: 05 February 2008, 20:38:04 »
All too big :(
« Reply #3 on: 05 February 2008, 20:43:51 »
I can't think of any other suppliers....  :(
« Reply #4 on: 05 February 2008, 20:50:51 »
Yes, will post part numbers tomorrow......plenty of alternatives to RS (Rippoff Spares) and Maplins (Former electronic components supplier who now specialise in tack).
« Reply #5 on: 05 February 2008, 20:55:24 »
Maplins really piss me off - they used to be a decent(ish) components supplier for the enthusiast.  Now they are a similar to 'Innovations' and sell junk :(
« Reply #6 on: 05 February 2008, 20:56:09 »
And will probably go the same way as Tandys when they wanted to become a computer component supplier
Martin_1962
« Reply #7 on: 05 February 2008, 22:21:20 »
Thanks Mark - how's the condensor?
« Reply #8 on: 06 February 2008, 08:28:39 »
Due to be fitted once I can lay my hands on an Expansion valve thanks.
Ok.
Rapid Electronics is worth a look.
The switch size is 6mm x 3.7mm x 3.1mm button profile.
Looking at the PCB you should be able to squeeze a 6 x 6  x 3.1mm switch on (these are better quality) and it should just clear the Battery though hole connection.
Martin_1962
« Reply #9 on: 06 February 2008, 12:21:38 »
Ok.
Search appears broken - do you have a link?
