Author Topic: Aaargghhhh!!!  No one said . . .  (Read 3316 times)
Re: Aaargghhhh!!!  No one said . . .
« Reply #15 on: 08 February 2008, 17:14:09 »
Takes me about 30 mins to do a DIS pack........but you didnt want to hear that did you ;D
Tkaes me about 45mins to drink tea whilst watching Tunnie do a DIS pack ;D
I could do it in 30 mins, if it was not for the constant abuse!
You still stuck on this Theo? - Assume scuttle is off, can't remember combination of tools i used last time.
Plank across the engine with me sat in the middle allowed for best access
« Reply #16 on: 08 February 2008, 17:15:05 »
Crikey! what do you use as a mug - a bucket?
I guess watching is thirsty work- so you have to go for a couple of refills. ;D
« Reply #17 on: 08 February 2008, 17:16:11 »
If I tried that next job'd be changing the engine mounts.
« Reply #18 on: 08 February 2008, 17:16:33 »
Too right it was thirsty work ;D
« Reply #19 on: 08 February 2008, 17:19:07 »
Thats cause his throat is dry from all the shouting!
theolodian
  • I need a new avatar.
« Reply #20 on: 08 February 2008, 17:44:30 »
Well, that sorta explains it.  Resorted to the prybar and tore it out.  Wish I had done that last night, but didn't have prybar at the time.  It's completely breaked!  Rotted out, plates all spread apart with rust, just gone!  :o
One bolt is still in there.  Need to get pliers in there or something.  Then it's on its way back together . . .  :y
theolodian
« Reply #21 on: 08 February 2008, 17:47:10 »
Scuttle off, plenum off, wiper motor out.  Laying on airbox corner of car.
I will need the pluglead order to put this back together . . .  :-[
Golfbuddy
  • Cornwall
  • I'm On An Economy Drive
« Reply #22 on: 08 February 2008, 18:47:46 »
The story continues . . .
. . . apparently they don't make the E10 in 1/4" drive, or at least no one has ever seen one.  >:(
I got one more bolt out with a better 8mm socket, still have one more to go though.  :'(
Prybar on standby.  :-/
Apparently they do and I have got some.  :y
http://cgi.ebay.co.uk/BERGEN-TOOLS-7pc-1-4-STAR-TORX-SOCKET-SET-FACOM-MAN_W0QQitemZ300195370309QQihZ020QQcategoryZ30917QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
[size=24]        [/size][/b]
theolodian
« Reply #23 on: 08 February 2008, 20:15:11 »
If you can't get it the same day it's no use.  I got the DIS delivered the same day . . .
All running now.  About 5 hrs total plus running around.   ::)
« Reply #24 on: 08 February 2008, 21:43:54 »
Excellent, glad its all sorted now, [size=8]you blind bugger[/size] ;D
theolodian
« Reply #25 on: 08 February 2008, 21:48:31 »
I got fooled by it being so badly designed in terms of installation that I didn't think to look for little numbers.  ::)
TBH this is the first time that I have had to repair a wasted spark ignition system.  Never done a dizzy cap that had numbers printed on it . . .  :P :D
« Reply #26 on: 08 February 2008, 21:52:00 »
LOL - its sorted, thats all that matters :y
Has it had a HBV failure at some point?
theolodian
« Reply #27 on: 08 February 2008, 21:55:10 »
I think so, was replaced shortly before I bought it. Then there was the flood last summer that killed my starter motor . . .  ::) :(
