Carin Sat Nav
Started by Tommy, 20 January 2008, 17:58:53
jules
Hotel21 wrote 'Its doubtfull in the extreme if it is the head gasket at fault.  If it were burning 5 litres per week the car would leave a smokescreen behind it!'
jules
#46
UPDATE - Fitting in progress
JACKPOT !!!!
No I haven't won Euromillions, but when I opened the passenger kick panel, the first thing I saw was the elusive 6 pin connector sticking out of the loom above X1 !!!
I thought 'I can't really be that lucky can I ?'
Checked the colours and they matched, so plugged it in and voila the nav system fired.
Off out now to try and get the sound through the stereo - more soon.
PS TheBoy, both units work completely.
jules
Right, Stereo feed is a no-go for now, there are no pins in the connector to attach to. Will have to try a Scrappie sometime.
Today was pretty 'scrapheap challenge' tastic, a few challenges encountered and I will do a 'how-to' with pictures when I should be working on Monday.
So sat-nav is now in and working, only question left is how do I take the outer rear of the rear seat off to pass the cables through?
th
eThanks for all the help guys
Quote......
Pull the toggle at the front edge of the base of the rear seat to release the front of it. Lift the front edge and pull it forward a little - you won't need to remove it completely - seat belt buckles, heated seats etc etc. At the bottom of the side bolster is a square plastic ring that is held down via a metal tab which is welded to the body. Lever the metal tab up enough to pull the plastic ring foward & clear of it. Lift the bolster vertically & it will come out. Refitting is the reverse...... :-)
Jim
Is this the same six pin plug you found in the passenger footwell under the kick panel
jules
Indeed it looks identical in the picture.
That was it's location so I can't see it being a completely different plug.
Jim
#51
QuoteIndeed it looks identical in the picture.
So did you just plug the sat nav loom into this and then everything came to live.
And then did you route the loom to the boot to the carin cd and route it under the dash to the screen etc.
PS; Check out the meets , gathering section. There's a meet it Callander this Sunday about 2 o'clock :y
jules
Basically yes, sounds simple but it was quite a challenge  :y
Writing a how-to at the moment.
jules
