Author Topic: NCDC-2013 Info  (Read 11372 times)
DaveMarshall
  • Swindon/Cirencester
NCDC-2013 Info
« on: 19 February 2008, 19:04:00 »
Does anyone have any info on the Siemens NCDC-2013 Sat nav, Phone, CD changer set up.  I have one here that I may be removing at some point also is there any faults e.t.c I need to look out for?
Dave.
[SIZE=20]Vauxhall's breaking and wanted for breaking
E-Mail me at southwestvauxhallspares@yahoo.co.uk[/SIZE]
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: NCDC-2013 Info
« Reply #1 on: 19 February 2008, 19:13:51 »
Doesn`t  that require a Tech2 de-installation to make it sellable afterwards?
Others on the forum can advise on that one.
Radio & Decoding Technician
www.dndservices.co.uk
DaveMarshall
Re: NCDC-2013 Info
« Reply #2 on: 19 February 2008, 19:15:32 »
Don't know I assumed if I removed the stereo with loom and display and any other bits related it would work?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: NCDC-2013 Info
« Reply #3 on: 19 February 2008, 19:23:13 »
One of the Tech2 Guru`s will be along shortly to advise
From my understanding, the stereo and display wil  run as a matched pair, but may prove tricky to reinstall into all other vehicles if not de-paired correctly.
Re: NCDC-2013 Info
« Reply #4 on: 19 February 2008, 19:24:06 »
Should really be depaired whilst still in the car.  It *MAY* work if taken out with all components still present and stay together, but can't say for certain.
It should really be depaired then repaired in new car, using new car's security code.
DaveMarshall
Re: NCDC-2013 Info
« Reply #5 on: 19 February 2008, 20:04:21 »
I have the codes for it, what do they actually do when they remove it with tech 2?
    • 530D M Sport, 330i Coupe
Re: NCDC-2013 Info
« Reply #6 on: 19 February 2008, 20:12:31 »
2013 doesn't have phone. Is it definitely a 2013 or is it a 2015? Phone (Telematics) will be in glovebox if it's a 2015.
What screen is fitted? Colour or Mono?
I'll leave TB to give you an accurate description of the process, but unless the screen is in delivery mode it's useless for anyone else....
« Last Edit: 19 February 2008, 20:12:53 by VXL_V6 »
DaveMarshall
Re: NCDC-2013 Info
« Reply #7 on: 19 February 2008, 20:25:35 »
I thought it had a phone as it has the 10 numbers and the green and red button although maty be wrong, here are some pics.
Re: NCDC-2013 Info
« Reply #8 on: 19 February 2008, 20:31:59 »
How much you want for it if I come down and depair it (assuming you have the security code from carpass)?
The parts are all coded together, and coded to the immobiliser (hence the carpass needed).  Whether it will work without the immobiliser, or whether its just used in coding process in not know.
If not depair, and the units are seperated, they are bricks.
Re: NCDC-2013 Info
« Reply #9 on: 19 February 2008, 20:35:42 »
The numbers are for the radio inputs (prestored channels), the green/red buttons are for the sat nav ... I think.. only had mine working a couple of weeks, still learning !!. The hand book for the 2013 is bigger than the one for the car itself !!!
Re: NCDC-2013 Info
« Reply #10 on: 19 February 2008, 20:37:20 »
Spot on! Green button selects your 'home' location so Sat Nav can guide you home from wherever you are!
DaveMarshall
Re: NCDC-2013 Info
« Reply #11 on: 19 February 2008, 20:37:45 »
I hadn't really thought about any pricing yet I was just looking in to how to go about removing it, I do have the car pass for it.  Is the screen I have the colour display?  Sure I read these are pretty hard to get hold of?
Dave.
Re: NCDC-2013 Info
« Reply #12 on: 19 February 2008, 20:38:56 »
Dave.
most certainly .. full colour sat nav you have there :)
Re: NCDC-2013 Info
« Reply #13 on: 19 February 2008, 20:39:00 »
Dave.
Easy enough to get hold of...... just not at a sensible price.
« Last Edit: 19 February 2008, 20:39:22 by VXL_V6 »
Re: NCDC-2013 Info
« Reply #14 on: 19 February 2008, 20:39:12 »
Dave.
As said, you really need to depair, then repair in the new car is the proper way to do it.
Oh, no phone on 2013 BTW ;)
