Author Topic: Replace bose setup  (Read 3565 times)
denisaok
  • East London
Replace bose setup
« on: 05 March 2008, 22:12:19 »
Hi all
I known this might sound like a crime after reading posts and seeing lots of you wanting to install BOSE SETUPS .  But i want to install my kenwood setup + ps2 had it in all car .Do i have need to remove Bose amp or can i just remove the Vx unit and fit the kenwood unit.
To ask a question and feel idiotic for a moment is better than not to ask and be idiotic for a life time.
Re: Replace bose setup
« Reply #1 on: 05 March 2008, 22:14:06 »
You need to bypass the bose amp....not hard to do either if you get the correct part from a non bose car.
denisaok
  • East London
« Reply #2 on: 05 March 2008, 22:27:30 »
Thanks Marks DTM Calib
For the quick reply will pick loom up 2mor
« Reply #3 on: 05 March 2008, 22:29:07 »
You dont need a loom, in the drivers kick panel is a connector for the audio, on Bose cars the bose loom plugs into it, on non-bose cars it has a loopback connector....fit this loopback connector and it bypasses the amp.
« Last Edit: 05 March 2008, 22:29:39 by Mark »
« Reply #4 on: 05 March 2008, 22:31:20 »
It does have wires going down the car through that loopback plug.  From memory, its just to cd changer though...
« Reply #5 on: 05 March 2008, 22:32:18 »
True, but with a new head unit these are not required  :y
« Reply #6 on: 05 March 2008, 22:32:35 »
Just remembered, I have my MV6 one on dining room table ::) - just checked, just cd changer wires going through that plug, other than loombacks.
denisaok
  • East London
« Reply #7 on: 05 March 2008, 22:38:36 »
Thanks Guys
but what dose it look like
denisaok
  • East London
« Reply #8 on: 05 March 2008, 22:44:04 »
My Vx is a 2001 can i get loop from pre face lift or dose it have to be from face lifted mod
uktigger
  • Blackpool, Lancs
    • 2003 2.2 Omega CD
« Reply #9 on: 05 March 2008, 23:25:44 »
Don't most Kenwood HU's have line level outputs which can use the Bose amp instead of the internal one which is turned off in a menu?
I know mine does.
denisaok
  • East London
« Reply #10 on: 06 March 2008, 07:41:55 »
yes mine dose but how do i connect to the Vx loom
« Reply #11 on: 06 March 2008, 09:20:18 »
Bose amp input is not line level......its a higher voltage balanced output.
And the loom on pre and post faclift cars are the same and remember, they are fitted to all non bose cars.
denisaok
  • East London
« Reply #12 on: 06 March 2008, 13:56:39 »
But what dose it look like
« Reply #13 on: 06 March 2008, 19:43:57 »
Look in drivers kick panel, its the bloody great thing across alarm ecu, so you've seen it before ;)
denisaok
  • East London
« Reply #14 on: 06 March 2008, 21:43:33 »
Sorted Thanks
