Author Topic: Engine change omega b2 facelift.  (Read 6294 times)
Omega_2.2
  • Norway.
« on: 24 March 2008, 16:26:18 »
Hello
I am going to set inn a y32se in my omega 2000 model.
Change from y22xe 2000model to y32se ?? what i need to change ecu++
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Engine change omega b2 facelift.
« Reply #1 on: 24 March 2008, 18:00:11 »
ecu and a new wiring loom and the heater matrix is different you will also need a r28 transmission box and possibly a different final drive unit
i think!!!
Omega_2.2
  • Norway.
« Reply #2 on: 24 March 2008, 18:43:54 »
i think!!!
Do i really need wiring loom ? i get a ar35 so that is ok.and the most of the cooling i maybe change ??
« Reply #3 on: 24 March 2008, 19:31:18 »
Immobiliser will need recoding, as will gearbox ECU.  Different ABS ECU required...
Omega_2.2
  • Norway.
« Reply #4 on: 24 March 2008, 21:17:47 »
Using the same key and gearbox ecu is together with the ar35.
but abs ecu ? where is that part ?
Håvard.
« Reply #5 on: 24 March 2008, 22:02:58 »
Håvard.
The immobiliser and keys will have to come from 3.2 donor car, else will need recoding.
ABS ecu is bolted to ABS unit.
Omega_2.2
  • Norway.
« Reply #6 on: 27 March 2008, 22:12:39 »
Håvard.
Ok-i have Simtec today and 3,2 has Motronic so do i need to change wiring inside the car ? :-?
davlad22
  • Sunny Yorkshire
« Reply #7 on: 29 March 2008, 01:37:32 »
I wouldn't say so? Does the 3.2 have different speedo/rev counter though?
I know it has speed-sensitive steering which the 2.2 doesn't.
« Last Edit: 29 March 2008, 01:38:36 by davlad22 »
« Reply #8 on: 29 March 2008, 11:13:55 »
Got to be honest, its probably easier and cheaper to buy a 3.2 car...
Omega_2.2
  • Norway.
« Reply #9 on: 30 March 2008, 02:35:30 »
Maybe but 3,2 in Norway ??? not sold many of them here...i can get all parts i need from seller in Germany----What i need to be sure it works ?? :question
« Reply #10 on: 30 March 2008, 13:09:21 »
Buy a 3.2 car from Germany?
Be cheaper and easier
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #11 on: 30 March 2008, 13:17:04 »
Totally agree here, this is a bit "pushing warm $hit uphill with a sharp stick" really.
Surely if you can get the parts from Germany, you can get the car from Germany. :-/ :-/ :-/
« Reply #12 on: 30 March 2008, 13:20:25 »
Yup! Saw plenty when i was there.... infact anyware in mainland Europe has them.
  • Online Online
« Reply #13 on: 30 March 2008, 13:26:01 »
.... "pushing warm $hit uphill with a sharp stick"  ....
Must remember that one!  ;D  ;D  :y  :y
Omega_2.2
  • Norway.
« Reply #14 on: 30 March 2008, 17:08:55 »
Maybe but the car is already in parts and bye a car from Germany 3,2l and change parts or bye a car and use you think i shall do ?
i already have a great omega....cost me a lot... :)
