Author Topic: climate control illumination stopped working  (Read 4315 times)
tut
  • Hadleigh,Ipswich
« on: 24 March 2008, 18:01:15 »
The illumination on my 1998 Elite has stopped working on the climite control buttons. Digits still there but not lit up. Is this an easy job to do? if so could some kind person give me a few pointes to what I need and how to do it
cbs2
  • East Kilbride
  • Right....Fire Up The Quattro!!!
Re: climate control illumination stopped working
« Reply #1 on: 24 March 2008, 18:30:44 »
Easy enough job tut
Remove the stereo, the screw behind, the ashtray & the two screws behind that.
feel up through the stereo hole, find the metal bar & pull down. That releases the top of the panel. If I remember from mine, there is 4-5 bulbs
I'm sure theres a how to somewhere
Taking part in the 2010 sucata split charity banger run. www.sucatasplit.com
www.boozebrothers2010.co.uk
Ex-mig owner................For now
« Reply #2 on: 24 March 2008, 19:28:18 »
Guide in Maintenence Guides.
tut
  • Hadleigh,Ipswich
« Reply #3 on: 25 March 2008, 07:06:01 »
it is only the digits that do not light up, will this cure it? all buttons are lit.
« Reply #4 on: 25 March 2008, 13:14:14 »
5 bulbs - 1 each for the individual LCDs, 2 for all the backlights via lightguides
tut
  • Hadleigh,Ipswich
« Reply #5 on: 04 April 2008, 07:02:04 »
Had to take car in for something else, while the garage had it they looked at the air con bulbs they said they were all working fine. but still no illumination behind the digits they told me the main air con control panel was faulty and would cost around £700 quid to replace. Do you have any idea or thoughts on this? was thinking of looking on  ebay for a whole new unit?
« Reply #6 on: 04 April 2008, 08:24:13 »
Not a problem I've come across before.  Before taking their word for it, worth checking connector at back of unit, and testing the bulbs yourself.
tut
  • Hadleigh,Ipswich
« Reply #7 on: 04 April 2008, 08:25:55 »
just take it out and check yeah as per instructions on website?
« Reply #8 on: 04 April 2008, 08:27:00 »
Yup
cockneyboy100
  • watford
  • this aint me, its my cat
« Reply #9 on: 04 April 2008, 09:17:50 »
have got complete unit, if you need one mate
a little tip for you all, never buy stockings for a mermaid
tut
  • Hadleigh,Ipswich
« Reply #10 on: 04 April 2008, 10:12:00 »
does it all light up mate? if so how much fo yu want for it?
« Reply #11 on: 04 April 2008, 10:49:39 »
Soudns like they did a naff job then....
Question 1
If you look closely at the digits can you see them faintly?
tut
  • Hadleigh,Ipswich
« Reply #12 on: 04 April 2008, 10:51:46 »
yeah all pixels are there just not backlit
« Reply #13 on: 04 April 2008, 10:54:03 »
In which case it is failed bulbs......remove it and replace them, there are 5 but, some are harder to spot than others.
