Author Topic: changing stereo  (Read 2721 times)
kkarl
  • medway kent
changing stereo
« on: 07 April 2008, 08:37:35 »
i got a 2.5 tourer 1998 it got tape player no cd or changer... can i change it to any cd player and if do will it screw up all the display and paddle controls on stearing wheel... if not what can i do help ... plus dont have code for stereo that is in it so cant afford to play about
regards
kkarl
my idea involves a citrus fruit and some fireworks!!!!!!!
Re: changing stereo
« Reply #1 on: 07 April 2008, 09:10:34 »
Only factory fit stereos will work with the display and wheel controls without modification.
Most 'branded' stereos you can get adapters for to drive these, though room is tight behind for the adpaters, so you may not be able to fit both adapters.
Vx in their wisdom reversed 12v and ign wires, so you may need to reverse them.
kkarl
  • medway kent
Re: changing stereo
« Reply #2 on: 07 April 2008, 09:25:31 »
ok thanks.. next step would be to get a cd player out of a wrecked omega then,, or be a clever git and wangle a ipod to conect to the one i got... on that note .. whats best way round code problem
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: changing stereo
« Reply #3 on: 07 April 2008, 09:41:59 »
Codes are no problem
Radio & Decoding Technician
www.dndservices.co.uk
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: changing stereo
« Reply #4 on: 07 April 2008, 09:54:02 »
i have a philips CCR 600 with blaupunkt 6 disc cdc all provided with codes am looking for £30 all in should work with your mig! and keep the display and swc going!  worked perfectly when it was in my mig only reason i stopped using it was i upgraded to bose
Re: changing stereo
« Reply #5 on: 07 April 2008, 13:53:43 »
He would need to check the CD loom is in place...
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: changing stereo
« Reply #6 on: 07 April 2008, 17:01:58 »
if the CD Loom is not in place i can provide you with one but it wont reach the boot!!! might get to under the passengers seat but not much further!
i can also tell you how to wire the cdc but so can the boy and other members!
kkarl
  • medway kent
Re: changing stereo
« Reply #7 on: 07 April 2008, 22:02:10 »
no doubt can get a etension for cd loom,, maplins etc bound to sell the female male conectors
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: changing stereo
« Reply #8 on: 08 April 2008, 07:28:55 »
from top of my head its a 10 pin connector with 9 pins working!
