Author Topic: CCR 2006 Problem!!!!!!!!!!  (Read 9209 times)
andytheroo
  • West Yorkshire
« on: 21 March 2008, 20:58:40 »
Hi all. I have just bought a 1999 CDX estate. The only problem I have is that I am unable to play cds. I have loaded the magazine correctly and put  it in but nothing happens. The radio works fine. Any suggestions please.
Train dont stop Cambourne Wednesdays.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: CCR 2006 Problem!!!!!!!!!!
« Reply #1 on: 21 March 2008, 21:46:35 »
Any error messages on the screen?
Radio & Decoding Technician
www.dndservices.co.uk
andytheroo
  • West Yorkshire
« Reply #2 on: 22 March 2008, 09:42:24 »
No thats what I cant understand.Once the loaded magazine is in it does nothing. When I select cd the word Magazine comes up on the led display.
« Reply #3 on: 22 March 2008, 09:57:56 »
Sounds like unit has failed, and needs servicing.  The changer portion of this set do seem delicate.
andytheroo
  • West Yorkshire
« Reply #4 on: 22 March 2008, 10:15:34 »
Im glad that Im not on my own. Any suggestions? Is it a dealer job or is there a chance I can do it?
Thanks again.
« Last Edit: 22 March 2008, 10:16:08 by andytheroo »
« Reply #5 on: 22 March 2008, 11:10:56 »
I know a few people on here are more familar with the cd changer portion than me, hopefully they can cast some light on what goes wrong. Likely to be mechanical within the changer mechanism I would suspect.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 24 March 2008, 15:19:34 »
Fairly common problem, but as Phiips and spares are no longer, not something we can repair I`m afraid.
andytheroo
  • West Yorkshire
« Reply #7 on: 27 March 2008, 19:30:51 »
Oh Bugger. Thanks for that.So unless anyone has one knocking about its looks like I`m ebay bound.
The Cambelt Kid
  • Derby
« Reply #8 on: 29 March 2008, 22:12:22 »
Could the switch at the back of the inside cd changer unit be knackered?
Might be worth stripping down and running on a bench if you are ok with electronic type of repairs?  I certainly would if i had the problem.
Cheers
[size=18]Project LP6 has landed![/size]
[size=12]DIY LPG now finally complete!! Whoo hoo.[/size]
davlad22
  • Sunny Yorkshire
« Reply #9 on: 30 March 2008, 23:41:03 »
Mr DND, did you say the magazine/changer internals can be swapped from a stand-alone CDC2??? (or something like that!?!)
Andy. the changer is not recognising the magazine, the exact same message is shown on the screen if the magazine is not inserted and you try to operate. Maybe that will lead you nearer to the problem if you fancy taking it apart???
« Reply #10 on: 31 March 2008, 08:52:14 »
CDC3 (4 disk one) is more likely I'd guess...
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #11 on: 31 March 2008, 09:06:33 »
NOT THE CDC2 !!!!!
If you can get your hands on a CDC3, its a very easy repair / swap
From your new in dash single Din CDC3, take off the plastic fascia assembly, remove the lid and take out the vertical PCB on the right hand side.
Replace the vertical PCB with the one from your old unit, as this contains the programming for use with the CCR2006 put the lid on from the old unit.
once board swapped, replace the entire unit, chassis and all and plug back in.
Should take you around half an hour and not really rocket science to do.
cockneyboy100
  • watford
  • this aint me, its my cat
« Reply #12 on: 31 March 2008, 15:52:13 »
hi have just replaced, my head unit with a sony, but still have kept bose system, sounds great,
now have spare  crt 800  and a cdc 2. both in working order, with codes.
pm  me, and we can go from there
phill ;)
a little tip for you all, never buy stockings for a mermaid
« Reply #13 on: 31 March 2008, 18:49:48 »
phill ;)
Surprised the Sony sounds OK through Bose - the levels are all wrong.
To clarify for those who may be interested, are you selling a ccrt700 or a ccr800 - there is no such thing as a crt800 ;)
andytheroo
  • West Yorkshire
« Reply #14 on: 31 March 2008, 20:51:17 »
Sorry I havnt replied sooner. Thanks for the above info and ideas. Now for the daft question What tools do I need to get it out?
THANK YOU ALL VERY MUCH.
I never got this much help on the Rover forum STUNNING!!!!!!!!!!!!!!!!!! :)
Page created in 0.026 seconds with 20 queries.
