Author Topic: Bose shelf speaker installation - Saloon  (Read 6609 times)
Re: Bose shelf speaker installation - Saloon
« Reply #15 on: 29 April 2008, 22:41:28 »
Marks_DTM's prefacelift is a 99 car, so it must have changed between 98 and 99 then?
M_DTM - did you measure mine at Telford?
No, I was to busy with my head under the other end :y
You got the 4 small holes for the mounting screws for the subs?
NickA
  • Cambridge
« Reply #16 on: 01 May 2008, 20:05:10 »
yes mark shelf has holes nearly out only discs held in with small amounts of meatel :y
Just been and double checked.....unless the indents are only in the top of the panel, there is nothing  :-[
When I fitted mine the rear shelf definitely didn't have any cutouts. That's on an 02 plate MV6.
psnimv6
  • tyrone n ireland
« Reply #17 on: 04 May 2008, 18:48:11 »
my 01 mv6 is the same no holes at all and i also have a bose to install so will be watching with interest what the experts do on this  :)
« Reply #18 on: 06 May 2008, 09:12:15 »
Can anybody measure the hole diameter for the rear metal shelf holes..........think I am going to buy a hole saw!
« Reply #19 on: 06 May 2008, 10:59:55 »
I may still have my old metal knockouts, if so, I'll measure then (not so easy to measure hole with speaker in place).
The speaker bit is round (even though top of bose bass speakers aren't).  The cut in carpet bit of parcel shelf is D shared, with the slots for the grill clips.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #20 on: 08 May 2008, 22:19:17 »
My 51 CDX is the same, solid rear shelf.
I am looking to fit 6'' speaker in the back have a feeling i will have to get the nibbler out for this.
Am yet to see a drill attachment that will drill out a 5'' hole
« Reply #21 on: 09 May 2008, 14:10:13 »
You can get upto a 6 inch cutter for mild steel.
The Bose appear to be 5 1/2 inch
« Last Edit: 09 May 2008, 14:10:37 by Mark »
