Author Topic: Brake lights stuck on when headlights are on!!!  (Read 8778 times)
Sabs
  • Epsom, Surrey
« on: 12 May 2008, 15:30:04 »
Dear All,
Im new to the frum; have a V reg 2.5 Elite with the works attached to it; its an AUTO but has a few niggles i need your help with please.
When i switch on the headlights, the brake lights stay permanently on!  But with the headlights off; they operate correctly!
Do you guys have any idea of what the problem could be?
Also, the AUTO gearbox has a mind of its own i think.  Ocassionally it will come up on the dash as "Auto Gearbox" and then it wont select any gears i.e stuck in third i think; once i swthc it off and on again; its fine, Ive had the module changed, still to no avail
Any helps guys would be greatly appreciated
Regards
Saboor
Andyb
  • Lincoln
Re: Brake lights stuck on when headlights are on!!!
« Reply #1 on: 12 May 2008, 15:45:53 »
could it be a sticky fog light switch
does the high level brake light light also
could be an earth
« Reply #2 on: 12 May 2008, 17:44:58 »
Check the rear earth, its behind the plastic trim on the boot slam panel on the passenger side.
Sabs
  • Epsom, Surrey
« Reply #3 on: 12 May 2008, 17:57:25 »
Behind the rear panle in the boot - as in where the spare tyre is?
And yes the high level brake light stays on tooo
How could an earth casue the lights to stay on i wonder; though i will check asap!
Ill report back with the findings; take it off givei t a good clean and see what goes from there!
Saboor
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
« Reply #4 on: 12 May 2008, 18:19:42 »
does the brake pedal have an adjusteer for the plunge switch
dieseldonicely
Sabs
  • Epsom, Surrey
« Reply #5 on: 12 May 2008, 18:27:24 »
i cant see it being the brake switch staing on; as when the headlights are OFF, then the brake lights perform correctly!  So it cant be the adjuster being too loose!
going to check the earth; car is out at the mo; see what goes!
« Reply #6 on: 12 May 2008, 19:45:17 »
check fluid level in box. :y
Sabs
  • Epsom, Surrey
« Reply #7 on: 12 May 2008, 21:00:48 »
i sound so bloomen stupid saying this; but is there an auto box dipstick?  i havent really seen it tbh anywhere in the bay; but will look on the pics provided by the site and locate it; will let you know.
Its only when i move the selector around from reverse to drive to 3rd; all the selector lights come on and then the fault message comes on the display!
« Reply #8 on: 12 May 2008, 21:02:49 »
there is no dipstick on omega box.i believe there is a how to in the relavent section for checking the level.
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
« Reply #9 on: 12 May 2008, 21:35:01 »
Do the headlights come on when you apply the brakes??.    If so it could just be a bulb in wrong or incorrect bulb.
lee
mega3.0v6
« Reply #10 on: 12 May 2008, 21:36:02 »
check that you have not got a single filament bulb in the brake light holder this can also cause this to happen silly it sound i know but has been known. It is where the single bit is making a contact between the 2 prongs.
LOL lee we posted at the same time.
« Last Edit: 12 May 2008, 21:36:59 by mega3.0v6 »
« Reply #11 on: 13 May 2008, 01:49:14 »
I'd almost be willing to bet it's either the wrong bulb or fitted the wrong way around! I wish people who don't know how to fit atlas would learn! It's hardly rocket science!
Oops... Sorry, that sounded like a rant! :-[ :-[ :y
Sabs
  • Epsom, Surrey
« Reply #12 on: 13 May 2008, 09:28:59 »
if its a bulb; honest guys ill slap myslef and then allow everyone you gys to do it too!
Ill admit, im a bit scared now, because i did change the bulbs on both sides; HOWEVER; i ensured i bought the correct bulbs from the halford in store guide; now lesson learned, i shall go to VAUXHALL and see if it makes a differernce, they are only bulbs so wont cost a fortune!
« Reply #13 on: 13 May 2008, 09:38:33 »
My moneys on the bulbs ;)
« Reply #14 on: 13 May 2008, 09:42:45 »
I know what I'm after and still find a lot of these Guides confusing!!
Before you rush out for new bulbs... Take the old ones out and try turning the lights on... You'll get Headlamp/Tail lamp warning come up but if the bulbs aren't in then they can't complete the circuit!!
We might be wrong but that's the most common problem... Quite often they get forced in the wrong way around (offset pins dictate correct orientation of bulb in holder) and can short across both pins!  :y :y
Oh, and I wasn't having a dig at you by the way... My pet hate is people who change headlamp bulbs and manage to get them in the wrong position so they blind every other person on the road at night!!  >:( >:(
