Author Topic: Projector headlamps  (Read 2329 times)
Projector headlamps
« on: 15 May 2008, 15:39:40 »
Just out of interest, do the projector headlamps have the same/similar lever inside to cut off the RHD upsweep of the dipped beam pattern for continental driving?
There's a discussion on a caravan forum debating where you'd use 'beam benders' or tape on modern clear, smooth headlamps, where the beam pattern is dictated by the reflector ie Omegas. I can't see that tape etc stuck to the lens will make the slightest difference to the dipped beam cut-off.
Re: Projector headlamps
« Reply #1 on: 15 May 2008, 15:47:37 »
Omega projectors have the lever (both normal and HIDS I believe - HIDS definately)... nearside one is a pig to get to .. the battery gets in the way if you have big hands like me !!
Very easy to do once you've done it a few times, I now do mine at the quayside whilst awaitng the ferry.
Works well
 :y :y
« Last Edit: 15 May 2008, 15:48:21 by entwood »
« Reply #2 on: 15 May 2008, 15:50:24 »
Works well
 :y :y
So ....is it just Vauxhall then that fit them? As said, surely a bit of tape so far away from the reflector is going to do SFA to the dipped beam pattern.
« Reply #3 on: 15 May 2008, 15:52:42 »
Works well
 :y :y
Tape wont help you on an Eliptoid lense headlight.....
« Reply #4 on: 15 May 2008, 15:59:05 »
That's what I thought. So that would lead me to think that all reflector headlamps must have a similar lever set up to an Omega to mask off the RHD upsweep of our dip beam.
« Reply #5 on: 15 May 2008, 16:03:31 »
I completely agree. But there are loads of experts on the site that would prove me wrong! ::)
 :-? Where'd your BIG post go to Entwood?  :-?
« Last Edit: 15 May 2008, 16:04:59 by Andy_B »
« Reply #6 on: 15 May 2008, 16:07:29 »
Deleted ..'cos it was too big !!! :)
and if your are on about "caravan talk" site there are far too many prats on there who THINK they know a lot ........ (Did you know that according to 3 of them the mega is FWD !!!  :)  )
« Last Edit: 15 May 2008, 16:09:10 by entwood »
« Reply #7 on: 15 May 2008, 16:11:10 »
Every setup I have seen has the levers.
« Reply #8 on: 15 May 2008, 18:27:07 »
I was. ::)
If they say it's FWD then who am I to argue?  ;D
