Author Topic: Alarm problem - where to start?  (Read 5373 times)
The Barge Captain
« on: 18 May 2008, 00:40:09 »
My alarm has started going off usually about 5 mins after locking the car.  Horn sounder and faint power sounder.  Unlock the car and silence power sounder then re-lock and all ok then.
Very annoying.
Where should i start looking?
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Alarm problem - where to start?
« Reply #1 on: 18 May 2008, 01:16:45 »
check the bonnet switch sensor it is on the passengers side near the pollen filter its alittle sticky up thing with a rubber boot on it  d/c and see what happens or it could be an expiring powersounder
perfferle
  • North Yorkshire
  • All cats are grey in the dark!
« Reply #2 on: 18 May 2008, 08:40:16 »
Right on TMX!
99% of the time the bonned switch is the culprit. Mine is still disconnected though - must get arround to replacing it :y
batista
  • yardley wood birmingham
« Reply #3 on: 18 May 2008, 08:41:56 »
either disconnect bonnet switch or pull the mounting bracket up ,so it makes a better contact :y
The Barge Captain
« Reply #4 on: 19 May 2008, 11:13:42 »
Ok.  I'll give it a try.
Thanks.
The Barge Captain
« Reply #5 on: 21 May 2008, 08:55:22 »
Well, the bonnet switch checked out electrically, so I removed the power sounder.
Batterys FUBAR'd and leaked over PCB.  What a surprise  :(
Will try and post some pics later.
