Stereo system gone unexplainably faulty.....
Started by Danny, 02 May 2008, 21:26:35
Danny
so its possible i may just need to re-seat the radio unit? i havent been able to get down to my car cos i've been a bit busy tho so its not yet sorted
how could it have disconnected itself though? it's been fine all along then suddenly i get in it and its not working
Ok, think I need to explain this a little better!
I am NOT sudgesting that a fuse is blown.
What I am saying is that the screen and radio appear to only talk codes when first powered up so if for some reason the code in non-volatile has become corrupt, it needs the power cycling to get them to re-communicate.
The no function operation is due to the radio and display having not verified they both have the same code.
Danny
thank you for all your replies, I went to the garage on friday to collect my car so i could begin faffing with the radio, they'd left the ignition in the ON position and flattened the battery!!
upon charging enough for me to start it, i turn the key and lo and behold the screen comes on fine, and all functions resumed as per correctly!!
had the battery not been flattened i think removing then replacing the main unit would have also been sufficient to cure the problem!!
garbage456
so did you not have to type in your code?
because I have the exact same problem
radio works can change station using left and right buttons plus can change volume but thats it, no other buttons are working.
garbage456
#19
QuoteCould you tell me which fuse it is please? (sorry, i really am rubbish)
the car is at the garage (another story) but i can nip down and faff with it anyway
F12!
YES ITS WORKING AGAIN, just take out the fuse and put it back in.
honestly I dont know how you knew that but thank you.
Danny
i couldnt even change the station with the left/right buttons!
because it's paired properly with its computer, a code wasnt necessary, which is good because i dont seem to have the car pass!
good to know yours is working again too :y
