Author Topic: lights problem  (Read 1893 times)
charlieboy
  • Harleston, Norfolk
lights problem
« on: 25 May 2008, 16:03:55 »
hi all, just come up with a small problem, when I switch on lights the dash lights  go    out, I had been towing a small trailer so thought the trailer electrics were faulty, but I only bought the lights board two weeks ago, now when the trailer is disconnected from car, the dash lights still go out when I swith on the lights, Is this just a small fuse problem or something else, any advice would be most welcome, thanks :-?
charlieboy
Re: lights problem
« Reply #1 on: 25 May 2008, 17:14:20 »
The variable / dimmer wheel on the main light switch isn't at minimum is it? Try moving it quickly back & forwards a few times, the track can get dirty / worn.
« Last Edit: 25 May 2008, 17:14:45 by Andy_B »
charlieboy
Re: lights problem
« Reply #2 on: 25 May 2008, 17:28:01 »
thanks Andy B , done as you said a few times and it seems to have done the trick, I am indebted to you..... what a great forum, the expertise of members have helped me several times now....
charlieboy
Re: lights problem
« Reply #3 on: 25 May 2008, 17:46:22 »
...... done as you said a few times and it seems to have done the trick, .........
Good. the cheap, easy fixes are always the best. It's a common Vauxhall/Opel thing!  ;)
