Sat Nav Problems
Started by humbucker, 07 March 2008, 13:03:23
humbucker
Hi all, hope you can help. I've got the Philips Integrated Sat Nav in the car. All the components seem to be 'alive' and working, but if I program a destination in it's as if the car just doesn't know where it is. I'm not quite sure what component I should be looking at to troubleshoot but if any of you have any ideas or have experienced something similar I would be very grateful of your advice.
Thanks!
http://www.irmschermv6.com | #irmscherMV6
PM with your requests.
jules
Put the unit into service mode from the menus
Code is 6330
Check that the GPS mouse is working.
Hotel21 wrote 'Its doubtfull in the extreme if it is the head gasket at fault.  If it were burning 5 litres per week the car would leave a smokescreen behind it!'
Dave DND
Newly Fitted? or just gone wrong?
If gone wrong, then check how many sattelites you are rceieving and then diagnose via the service mode menu as previously mentioned.
If newly fitted, leave in an open area with a clear view of the sky and switched on - it will then "learn" where it is as the sattellites pass overhead - this can take a while, and from memory, when we installed them new, many, many years ago, two hours was not uncommon.
Radio & Decoding Technician
www.dndservices.co.uk
humbucker
#3
QuoteNewly Fitted? or just gone wrong?
it's the factory fitted philips satnav, it just doesn't seem to know where it is! i'll put the code in as instructed. everythin else seems to be functioning properly, at least it is powered up and alive.
its as though it was programmed by stevie wonder or something.
i take it you can check the number of satellites within the service mode menu?
humbucker
#4
the sat nav in question can be seen mounted in the dash next to the phone in this pic if it helps:
jules
As said above, you need to verify that the GPS mouse is receiving satellite information.
We are talking about the same system you show in your picture. It's a CARIN made by philips
Yup, need to check that its seeing satelites, I suspect its not...
humbucker
Ok I'll have a play about and see what it says. If it turns out that it ISNT seeing satellites is there a quick fire solution to this, or ANY solution (other than buying a tom tom hehe)?!
QuoteOk I'll have a play about and see what it says. If it turns out that it ISNT seeing satellites is there a quick fire solution to this, or ANY solution (other than buying a tom tom hehe)?!
Check wiring from gps antenna to CD unit.
humbucker
#9
'K, thanks, I'll let you know how I get on
jules
GPS is mounted under centre vents.
Runs left to passenger kick panel then down sills through rear seat grommet to unit in boot.
On my saloon loom, the gps mouse also has an extension lead connected to it, this will be somewhere from the pass kick panel to the sills, if this is loose it will cause problems
Dave DND
Its not uncommon for the GPS receiver to fail - readily available on ebay for under £20 - just make sure you get the correct connector on the end to make life easier.
humbucker
I checked through the service menu last night and the GPS status is either 'SEARCH' or '----' so I'm guessing it's not picking up any satellite signal. I'm going to go out and check the wiring this morning, but it's reading from the disc OK, doing everything it should, just not sure where it is and therefore telling me to 'take a U turn' every five seconds hehe.
If wiring seems OK I guess I'll have to look out on Ebay. Is the receiver the little dash mounted box?
jules
Reciever is usually a black square, with a coax lead coming from it, ending in an SMB-F connector.
I have one £10 inc postage.
QuoteI checked through the service menu last night and the GPS status is either 'SEARCH' or '----' so I'm guessing it's not picking up any satellite signal. I'm going to go out and check the wiring this morning, but it's reading from the disc OK, doing everything it should, just not sure where it is and therefore telling me to 'take a U turn' every five seconds hehe.
Yup, mounted near tax disc on early ones or under by centre vents on later.
