Author Topic: cid bad pixel(s)  (Read 2699 times)
cid bad pixel(s)
« on: 24 May 2008, 00:18:13 »
searched this, no results so here goes. Got new 3.2 elite with colour info display
very nice but there is usually a bad pixel on the screen. Yes i am fussy! It shows on the black vauxhall screen (radio off) as a red pixel then black on a white screen when radio on. It seems to be on the same vertical line, but the hight it appears at will vary. Thinking dodgy connection on that row? Or is this common problem and just how they are? Thanks
Re: cid bad pixel(s)
« Reply #1 on: 24 May 2008, 09:25:39 »
The panels that are used (Sharp ones iirc) are not renown for their reliability.  It is possible to replace the panel itself if you have the necessary skills and equipment, though seem to recall buying new panels is getting difficult now.
jon
  • oxford
« Reply #2 on: 24 May 2008, 19:11:06 »
I had this same problem on my CID which very quickly became the common gray vertical line problem and totally unusable. I sent my screen to this company in Germany www.pixelfehler-hh.de/index.php. They had it returned in three days with a warranty, and their english was perfect.
« Reply #3 on: 25 May 2008, 00:09:50 »
wow theyre the kiddies. Thanks very much for info. I guess leave it  and hope it does not get any worse.
Cheers.
wingman
  • Hastings
    • Grandland GS
« Reply #4 on: 31 May 2008, 18:16:09 »
You could also try BBA Reman at Rochester, Kent if you want (www.bba-reman.co.uk) rather than sending to Germany
They replaced the screen on my CID for circa £180 with a 2 year warranty (spk to Nigel at BBA)
« Reply #5 on: 01 June 2008, 17:24:04 »
Thanks Wingman, will talk to them about my mates buggered abs ecu as well, did not realise they do both. ..... :y
