Author Topic: Rear Indicator lights not working  (Read 2783 times)
chipito
  • West Midlands
« on: 10 May 2008, 13:44:21 »
On my 52 reg Omega 2.2 the rear indicator lights have stopped working.
I thought it was down to a blown bulb but both left and right have stopped working (resulting in a high flash rate from the front and side bulbs) but the lights themselves still work when I put my hazards on (which shows the bulbs are OK).
Could it be a faulty stalk on the steering column?
shanjon
Re: Rear Indicator lights not working
« Reply #1 on: 10 May 2008, 13:53:09 »
i would have thought it unlikely to be your stalk if the front are working as they should,
relay ? maybe
its a strange problem this
« Reply #2 on: 10 May 2008, 13:56:24 »
Press the hazard switch on/off 20-30 times .. :)
They are known to cause problems and this sometimes sorts them ... no promises mind ..  :(
HTH
Dazzler
  • Haverhill, Suffolk
« Reply #3 on: 10 May 2008, 15:33:00 »
Very strange, as indicators are normally in pairs left and right not back and front :-/
chipito
  • West Midlands
« Reply #4 on: 10 May 2008, 16:08:56 »
Press the hazard switch on/off 20-30 times ......
Tried that.
No joy.
It's an intermittent fault and for the first 30 seconds or so on start up, the indicators work fine.
Perhaps (due to this) it's a voltage related issue but to be honest I'm just guesing here.
A mechanic friend said he'd never heard of such a thing either but that he'd check for earth shorts and run a multimeter over it next week.
In the meantime if anyone has come across a similar problem then I'd be grateful for input.
Cheers chaps .....
« Reply #5 on: 10 May 2008, 16:24:43 »
Check the earth point in the boot, its on the passenger side behind the boot plastic trim panel.
« Reply #6 on: 10 May 2008, 17:31:24 »
Beat me to it! I've been thinking over what fault could be and came down to dodgy wiring/earth!
chipito
  • West Midlands
« Reply #7 on: 15 May 2008, 00:44:43 »
Earth point checked and at 100%.
After a day of sitting outside the house, it all appears to be working normally now.
Sods law says it will start to play up just before its next MOT though.......  :-?
lordpsk
  • Gwynedd
« Reply #8 on: 29 May 2008, 16:34:13 »
I had a similiar fault were the rear tail lights stopped working, traced the fault to the multi plug behind the footwell side cover on the n/s front footwell,
check wires on either side of plug and I think you will find that is the problem :)
chipito
  • West Midlands
« Reply #9 on: 05 June 2008, 21:43:31 »
All sorted now.
It turned out to be a faulty relay which was located behind the spare wheel.
The small black box is marked Blinkúberwachung.
£35 later and I have full blinkability.  ;D
