Author Topic: a change of project....  (Read 3396 times)
Re: a change of project....
« Reply #15 on: 09 February 2008, 21:48:53 »
is that eml on?
engine not running....
I knew that ::)
have you got some small ish jubliee clips? I am missing both on the front inlet from the mini bagpipes to the plenum...
« Reply #16 on: 09 February 2008, 21:51:05 »
is that eml on?
I knew that ::)
I have some cheapies somewhere, as long as it doesn't need to be mega tight...
« Reply #17 on: 09 February 2008, 21:53:54 »
is that eml on?
I knew that ::)
They are already tight on, it need to be nipped on.
I think in the rush James did not tighten the plenum jubliee or airbox ones... so i suspect i may have a few codes stored  ::)
I also 'borrowed' the multi-ram stuff from the old project... so that needs fitting too.
Might need you to take it for a damn good ragging gentle drive, as i have felt a large nocking noise from the drivers side front, think its the wishbone  :-/
« Reply #18 on: 09 February 2008, 21:56:25 »
is that eml on?
I knew that ::)
I'm in tomorrow morning...
« Reply #19 on: 09 February 2008, 22:01:25 »
is that eml on?
I knew that ::)
I have to be up early anyway, so will drop by  :y
« Reply #20 on: 09 February 2008, 22:16:19 »
is that eml on?
I knew that ::)
Bring your halfords set round - I think we've got a socket mixed up...
« Reply #21 on: 09 February 2008, 22:17:40 »
ahh yes E14...
« Reply #22 on: 09 February 2008, 22:18:33 »
ahh yes E14...
Ah. I was hoping you had 2 E10s
« Reply #23 on: 09 February 2008, 22:20:20 »
ahh yes E14...
I have 2 of something in the E range, not sure what!
« Reply #24 on: 09 February 2008, 22:26:25 »
ahh yes E14...
I think I have 2 E11s, but missing E10.
Check your estate handbrak cable for a rachet spanner ::)
« Reply #25 on: 09 February 2008, 22:28:17 »
ahh yes E14...
Might pop it on some stands and take a look  ::) - Need to investigate the wishbones anyway.
