Author Topic: traction control and abs lights  (Read 4153 times)
martin12760460
  • Poole dorset
  • "if it moves funk it"
« on: 03 June 2008, 16:36:18 »
Why would these both come on all of a sudden ? they just apeared after goin round a slippy r/about and just stayed on  any ideas please  :(
Re: traction control and abs lights
« Reply #1 on: 03 June 2008, 16:43:50 »
Problems with speedo as well ???
ABS ECU failure ???
http://www.omegaowners.com/forum/YaBB.pl?num=1152729807
If you have all these .. then bba-reman are the folks to speak to. They saved me a fortune versus the stealers !!
01634 230055
http://www.bba-reman.com
HTH
« Last Edit: 03 June 2008, 16:44:17 by entwood »
MutantCav
  • Gainsborough
« Reply #2 on: 03 June 2008, 19:37:23 »
I have 2 of these units (traction control and abs control with ecu) in my garage...both off of fully working cars...can send you one for £45 delivered :)
martin12760460
  • Poole dorset
« Reply #3 on: 03 June 2008, 20:34:23 »
thanks but how hard to fit ?
« Reply #4 on: 03 June 2008, 20:39:20 »
I believe it is a simple procedure ... 6 bolts..... but damned tricky to do !! due to the location and positioning ...
The link I gave at the top explains how to change .. :)
MutantCav
  • Gainsborough
« Reply #5 on: 03 June 2008, 20:49:01 »
2 bolts to remove...plus the ones for the wiring...as said, tricky to get to but easy to do...
« Reply #6 on: 03 June 2008, 21:14:01 »
Simple procedure - absolute barsteward!!  Fiddly, lack of room and bl**dy awkward.
I've done one - but don't let the above put you off.  Its a hell of a lot cheaper than the stealers - quoted £1000 for mine!!  Cost £45 for 2nd hand unit (off exact same model & year - important that) - worked a dream.
« Reply #7 on: 03 June 2008, 21:15:26 »
No 6 torx bolts - u can only see top 2, have to undo other 4 by feel only!
martin12760460
  • Poole dorset
« Reply #8 on: 05 June 2008, 18:47:14 »
i havve wiggled  all wirers  i can find and is all ok at the moment  8-)thanks for all your help and i will keep you  posted thanks again :y
Hammers
  • Berkshire
« Reply #9 on: 06 June 2008, 09:16:11 »
Just had the local garage fit new discs and pads all round, and since then every now and again the abs and tc lights come on and the speedo stops working. Going to check all the sensors at the weekend hope this stops it. :'( :'( :'(
« Reply #10 on: 06 June 2008, 11:05:02 »
Chances are they've been ham fisted and damaged a sensor or wiring. I'd chuck it back at them, TBH.
You can read trouble codes from the ABS to identify any sensor it has flagged as faulty. Perhaps you could get them to put a code reader on it FOC? Needs to be a Tech 2 or, if you're lucky, a cheapo.
MutantCav
  • Gainsborough
« Reply #11 on: 06 June 2008, 12:55:24 »
There is a sensor for the system on the rear wheel/s I believe, probably what they have disturbed...
« Reply #12 on: 07 June 2008, 09:53:49 »
Be odd if they'd touched the rears when doing brakes  :-/
Hammers
  • Berkshire
« Reply #13 on: 07 June 2008, 13:20:28 »
It had discs and pads all round plus the o/s/r caliper had seized so that had to be replaced. Going to check the sensors if thats not it going to take it back to the garage and give em both barrels ;D ;D ;D
