Author Topic: Adjusting dual climate temp controls together  (Read 5322 times)
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« on: 11 June 2008, 17:49:57 »
Is it possible to adjust the temperature of both sides from the drivers control? TIA  :y
Trade club card holder
Code scanner available
Dazzler
  • Haverhill, Suffolk
Re: Adjusting dual climate temp controls together
« Reply #1 on: 11 June 2008, 17:52:14 »
My climate panel does......when i change the drivers one the passengers one follows, but they can also change theres which does not effect mine :-/
« Reply #2 on: 11 June 2008, 17:53:15 »
I normally start my climate in AUTO with the temps both set on low.
Adjusting the temp on the drivers side they both move at the same time, but if I alter the passenger side they then each need adjusting on thier own.
But I have no idea if this is normal operation as I am still getting used to it my self.
alexandjen
  • The Silver Surfer
« Reply #3 on: 11 June 2008, 17:54:04 »
Well mine operate independantly all the time which is a pain in the ar@e  ::)
« Reply #4 on: 11 June 2008, 17:55:50 »
Reset them.
alexandjen
  • The Silver Surfer
« Reply #5 on: 11 June 2008, 17:57:49 »
That just sprang to mind as you posted...I'll go and reset now.....auto and off for 10 secs isn't it?   Climate on or off for reset?
« Reply #6 on: 11 June 2008, 17:59:34 »
Press and hold OFF and AUTO at the same time for 10 seconds
If I am wrong one of the other members will corrent me.
alexandjen
  • The Silver Surfer
« Reply #7 on: 11 June 2008, 18:10:22 »
Ok I've just reset the climate..........I think  :-/
Is something supposed to happen when it has reset as nothing seems any different  :(  does anything flash to confirm reset?
« Reply #8 on: 11 June 2008, 18:10:56 »
2001, presumably a facelift, just press the passenger side knob - this will switch off display passenger side, and temps will follow drivers side setting.
Prefacelifts, if the get out of sync (ie, passenger adjusts their side), it will reset to follow drivers side after 40mins with ign off.
alexandjen
  • The Silver Surfer
« Reply #9 on: 11 June 2008, 18:20:53 »
Yes facelift, thanks TB  :y
garbage456
  • Carshalton, Surrey
« Reply #10 on: 12 June 2008, 19:59:36 »
if both sides are showing a temperature
press the drivers side, this will turn off the display on the passenger side,
adjust to the temperature you want,
press the drivers side again, both will come on.
thats it !!
2001 facelift elite
« Last Edit: 12 June 2008, 20:00:14 by garbage456 »
« Reply #11 on: 12 June 2008, 20:00:59 »
Sorry, hadnt picked up on that, my appologies.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #12 on: 12 June 2008, 20:48:02 »
Tell me what's wrong with my climate. Works ok, but pressing the drivers knob leaves temp reading on passanger side ( and I've got the steering wheel on left). If I change the wiring, I will get the display and function ok, but then I would change passengers temp while turning the drivers knob. Was this bad enough explanation of the status quo? Hope someone gets my point and knows what to do
« Reply #13 on: 12 June 2008, 21:00:10 »
Needs programming to state which side driver is - sounds like yours is programmed fot RHD
« Last Edit: 12 June 2008, 21:00:32 by TheBoy »
