Author Topic: Alarm horn?  (Read 2703 times)
tomoco
  • leicester
Alarm horn?
« on: 19 June 2008, 15:23:18 »
The alarm sounder packed up on me last year so i'm just left with the alarm horn. I set the alarm off the other day and its, well not the most impressive of sounds (beep beep beep) its a bit lame to say the least.
Is there a replacement (very loud) horn i could fit/wire up?. The alarm sounder made a much better noise but as its designed to go off when there is a voltage drop(battery disconnection) i cant see the point of replacing it(you would never hear it)
Thanks in advance
Mark
Re: Alarm horn?
« Reply #1 on: 20 June 2008, 10:49:09 »
Thanks in advance
Mark
Any 12V water proof horn should do the job....
Re: Alarm horn?
« Reply #2 on: 20 June 2008, 10:57:22 »
Thanks in advance
Mark
OOOooo, I have a 12v Klaxon style horn kicking arround, allways wondered what to do with it.
Re: Alarm horn?
« Reply #3 on: 20 June 2008, 11:10:56 »
I had a police siren on the ex-plod estate.......guess what that got wired into!
« Last Edit: 20 June 2008, 11:11:16 by Mark »
tomoco
  • leicester
Re: Alarm horn?
« Reply #4 on: 20 June 2008, 13:41:42 »
Thanks for the replies, was'nt sure of exact voltage because it pulses rather than a continuous supply. I know when i took the sounder apart it only had 2 x 3.6 volt ni-cads in it(7.2 volts) or was it 2 x twin packs of 3.6 volt ni-cads which would be 14.4 volts
Mark
P.S. Marks DTM .i'll be in touch soon about waking up (Tech-2ing) my retro fit cruise( still not sure if i have the clutch switch yet) Fitting the stalk today.
Thanks again peeps
Re: Alarm horn?
« Reply #5 on: 20 June 2008, 14:09:12 »
Mark
Thanks again peeps
No problem, as a temporary fix whilt sorting a clutch switch (if its not fitted) we can short the wires out to prove it works.
