Author Topic: Failed foggies!!  (Read 4366 times)
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
Failed foggies!!
« on: 23 June 2008, 20:00:09 »
Hi guys, the front foglights on my Omy have stopped working. Have checked/changed the bulbs for new ones (known to work!! H1's from the headlights  :y ) but still no joy. Fuse in fusebox is OK, tested/changed.
Is there a relay somewhere that might have gone up the swanneee, if so, where should I look for it?
All help gratefully received!!
Dodger..
I always knew I'd inherit an estate, but I never thought this would be it!
RobC_NE
  • North East
  • IMI and VSIB Qualified Auto Electrician
Re: Failed foggies!!
« Reply #1 on: 25 June 2008, 15:17:40 »
IIRC the front foglight relay is under the dash with all the fuses, easiest way to check if its working is put your hand over the lot turn headlights on and press the front fog switch, if its working you should feel it "click" under your hand. unfortunately i cant remember for definate which one it is. (for some reason i think its in the bottom left corner of the block)
Saxo, corsa, clit drivers. Before starting on a journey, attach a lit sparkler to the antenna of your car. you drive the thigs like dodgems. for the love of god MAKE IT LOOK THE PART!
« Reply #2 on: 25 June 2008, 16:17:07 »
Correct, small relay top left of the relay panel...
Dodger
« Reply #3 on: 26 June 2008, 20:34:02 »
Cheers guys!! the little relay, top left hand corner appears to be fubarred. Nil, nothing, zilch, when foggies switched on. looks like a trip to da stealers then, as local factors ain't got nothing that small.
probably no change from a tenner, knowing the local 'robbers'  ;D ;D
« Reply #4 on: 26 June 2008, 22:26:14 »
...... Nil, nothing, zilch, when foggies switched on. looks like a trip to da stealers then,  .....
No breakers/scappys around your way then? You'd be able to restock on spare fuses at the same time.  ;)  :y
JueV6
  • Kent
« Reply #5 on: 26 June 2008, 23:53:07 »
Thats standard with all scrappies, Go in with a very lightweight tool box and come out struggling to lift it.... ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #6 on: 27 June 2008, 08:33:05 »
I would be checking for volts on the socket before buying a repalcement item, relays rarely fail
Dodger
« Reply #7 on: 27 June 2008, 21:16:17 »
"No breakers/scappys around your way then? You'd be able to restock on spare fuses at the same time."
There are a couple, but somebody beat me to the only Meega with foggies fitted!! (have zillions of spare fuses/bulbs/screws bolts/widgets/whatchamacallits etc, Wonderful place, scrappy's... just ain't got a 'meega wiv foggies :'()
might well do as Dave suggests, get the meter out, and go voltage huntin' :y
markey mark
  • SLady bitshorpe north lincs
« Reply #8 on: 28 June 2008, 13:16:27 »
get me the number off the relay should have one matey ! :y
Dodger
« Reply #9 on: 29 June 2008, 19:49:44 »
Having poked about with the meter, I now suspect the switch itself, as volts at socket, when switch block removed, will now remove dual switches block from lighting block, and investigate further.
possibly insides of switch knackered??
might need a new lighting switch !! :(
vauxfan2k
  • Western Isles
« Reply #10 on: 13 July 2008, 18:40:48 »
According to the wiring diagram for the pre-facelift omegas. there is no relay for the front fogs, it is controlled directly from the headlamp switch Unit, I found this out when trying to fit fogs to a GLS model and couldnt get them to fit.
vauxhall dealer looked up schematic and said there is NO relay for the front fogs, turned out the connectors behind the front bumper had gone all green and werent transferring the power to the lights.
You can change the fog light switches independantly of the main switch unit, but replaceing the whole thing might be an idea.
Also worth changing the bulbs for illumination of the switch while you are at it.
Cheers
Dodger
« Reply #11 on: 15 July 2008, 18:53:51 »
Hi gang,
Turned out to be the switch, as I suspected. got one from the scrappy, (asked if I could try before buy  ;D) and as he could see my car from the window, came out with me, and using me credit cards...(see, they ARE useful for something!!)to remove the unit, swapped units..Voila!! Foggies all lit up..
charged me a fiver for the whole gubbins..
Job done, and I am on happy fella.
(thanks for all your suggestions/help guys. What a bunch of heroes) :y
« Last Edit: 15 July 2008, 18:54:24 by Dodger »
