Author Topic: car alarm  (Read 5426 times)
solidgold
  • brentford  middlesex
car alarm
« on: 16 July 2008, 21:10:31 »
hi
i was wondering if any one can help i just had my alarm checked it is connected but not sounding is there a fuse i can check if there is where and wat sort is it
thanks >:(
Danny
  • Wigan, Greater Manchester
Re: car alarm
« Reply #1 on: 16 July 2008, 22:45:48 »
do the indicators flash?
solidgold
Re: car alarm
« Reply #2 on: 16 July 2008, 23:14:32 »
the lndicators flash when sensors are set of in car
deks
  • Durham
Re: car alarm
« Reply #3 on: 17 July 2008, 23:31:59 »
i have a 2001 estate gls ,there is no sensors on the pillows ,and the light etc dont flash etc ,how do i check  or find the alarm (new to owning a omega ) cheers.
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: car alarm
« Reply #4 on: 18 July 2008, 00:18:40 »
if its flashing, and making no noise, then the powersounder (if there is one) will be buggered, and also most likely the horn sounder may be goosed too.
I had to fit a different horn to my Omega to get the alarm to make a noise (under the scuttle, drivers side, next to where the powersounder is located.)
If you want to test your alarm and cant see any interior sonic sensors (facelift position is with the courtesy light), leave a window open, lock the car and deadlock it (2 clicks on the remote), take the little chip out of the key blade (remove blade from the fob part, its the little chip in the blade end). and then after about 30 seconds after locking the car, try to start the car with the blade through the window with the chip removed.  DONT LOSE THE CHIP!!!!
If the only thing which happens is the engine management light flashes, but no indicators flashing or horn/siren, then you have no alarm.
« Last Edit: 18 July 2008, 00:20:06 by PaulW »
Humbugs...
deks
  • Durham
Re: car alarm
« Reply #5 on: 18 July 2008, 08:31:38 »
Thanks very much for the reply and help ,i will try that this morning ,just noticed too ,that my key fob has only two buttons ,think this might have been changed .Anyway thanks again .
vauxfan2k
  • Western Isles
Re: car alarm
« Reply #6 on: 18 July 2008, 18:44:24 »
I have the same problem with one of my omega's, the indicators flash but no horn sound, I checked the horn and it works. I tried a bulb connected to the loom for the horn and nothing happened, seems no voltage is going to the horn.
any ideas on that one?
cheers
deks
  • Durham
Re: car alarm
« Reply #7 on: 18 July 2008, 20:59:20 »
dont have a clue mate sorry ,mine is alarm is missing i think !! doing my head in ,having talks with the wife to sell the car at the moment !!!!
