Author Topic: Does sc804 have a separate amp  (Read 10847 times)
osealy
  • dublin
« on: 27 June 2008, 13:36:28 »
Elite Est 97 Preg . Does it have a separate amp? If so where is it.
Car has steering controls which wont work sc804 or ccr800 any ideas?
markey mark
  • SLady bitshorpe north lincs
Re: Does sc804 have a separate amp
« Reply #1 on: 27 June 2008, 15:58:05 »
in the elite yes think its under rear shelf ! to get steering controls working iirc you need new airbag squib and a bit of wiring too  :-/
osealy
  • dublin
« Reply #2 on: 27 June 2008, 17:10:34 »
Where would it be in an estate ?  & if there is an amp ,how powerfull.
markey mark
« Reply #3 on: 27 June 2008, 19:55:53 »
in one of the side compartments iirc its behind the cd changer  :y
osealy
  • dublin
« Reply #4 on: 27 June 2008, 20:20:48 »
not there. The sc804 is taken from a 95 elite was a straight swop. Would 95 have had an amp?
osealy
  • dublin
« Reply #5 on: 27 June 2008, 20:27:35 »
And is the steering wheel an add on on 97 P reg.
Admin
« Reply #6 on: 03 July 2008, 20:59:06 »
No, you will find that pre '97 cars had steering wheels too. ;)
The Administrator.
    • 530D M Sport, 330i Coupe
« Reply #7 on: 03 July 2008, 21:48:10 »
;D
« Reply #8 on: 04 July 2008, 09:09:58 »
ccr800 can be configured to work with remote controls via tech2. never seen one not preconfigured though  :-/
sc804 cannot use remote controls
some sc804 have amp, some don't.  Its a small amp, not corsa boyz 10000 watts, just to provide extra depth.
davlad22
  • Sunny Yorkshire
« Reply #9 on: 04 July 2008, 18:52:55 »
;D ;D ;D
osealy
  • dublin
« Reply #10 on: 10 July 2008, 23:06:19 »
I was too busy trying to cure hot running to worry about improved sound,
I suppose I should have seen that coming!
Should a 97 april P reg have steering controls (april) they wont work with ccr 800 either,
« Reply #11 on: 11 July 2008, 08:20:50 »
The only 804's with additional amps were some Elite Saloons (the amp is a naff philips thing just forward of the spare wheel well plus two speakers under the rear shelf but no grills above!).
oredona
  • chatham, Kent
« Reply #12 on: 30 July 2008, 17:30:39 »
i am having problem fitting this phillip amp to my pioneer radio, it just wont  work, i thought the amp was bad, i bought another one, but it is still not working. I connect it the way i belive it should be connected.
Has anyone changed thire car radio using the same phillip amp and if yes, please tell me how it was connected.
thanks
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #13 on: 30 July 2008, 17:40:24 »
You will probably find that the Pioneer shuts down and goes into protection mode if you try to connect it to the Philips amp.
Its not compatable.
Radio & Decoding Technician
www.dndservices.co.uk
DC
  • Switzerland
« Reply #14 on: 30 July 2008, 22:45:51 »
Earlier today went for a drive, put a Rory Gallagher CD in (one of my favourites) for the first time in this car and can tell you one thing: SC804 will be thrown out very soon, speakers to follow >:(
