Author Topic: Bulb not illuminating  (Read 1924 times)
Dr Jones
  • Wantage, Oxfordshire
« on: 31 July 2008, 13:40:42 »
Hi all
Got  a problem with the Air Con switch on my 98 TD
The symbol illumoinates when the side lights are on but the on/off light does not come on at all
Bought another switch and same problem - to rule out the chance of having bought a rubbish switch from flea-bay I opened the switch up and reversed the bulbs inside - it illuminated when the side lights came on - so it's not the bulbs.
Is it the connection behind the switch? Or the wiring behind the wiring control panel?
Many thanks
If you're not living life on the edge, you're taking up too much space!
Re: Bulb not illuminating
« Reply #1 on: 31 July 2008, 14:45:50 »
Do be aware that if there is a fault with the aircon setup (i.e.no gas) then the switch light will not come on.....which sounds like it may be the route cause.
Dr Jones
« Reply #2 on: 31 July 2008, 15:24:46 »
A-HA!
There is a leak on the condenser manifold (which my local garages and even air-con specialists don't want to touch)
Thanks for the advice.
