Author Topic: Bose amp  (Read 3079 times)
Cumbria
  • Southport. Merseyside.
Bose amp
« on: 31 July 2008, 00:08:10 »
Just seen a bose amp on ebay and was wondering if i could fit it to my crt 700. To improve the sound quallity. Also the alarm is not working indicators flash but no sound. Can anyone help please.
Dazzler
  • Haverhill, Suffolk
Re: Bose amp
« Reply #1 on: 31 July 2008, 00:11:03 »
Is this a facelift or pre-facelift car????
Cumbria
Re: Bose amp
« Reply #2 on: 31 July 2008, 00:13:10 »
Pre face lift 1999 cdx 2.5 v6
Dazzler
Re: Bose amp
« Reply #3 on: 31 July 2008, 00:15:28 »
The CCR700 should have the Bose amps etc.....already fitted :-/
Cumbria
Re: Bose amp
« Reply #4 on: 31 July 2008, 00:21:40 »
Sorry its not ccr 700 its ccrt 700. With the telephone.
Dazzler
Re: Bose amp
« Reply #5 on: 31 July 2008, 00:24:19 »
Yeah, and it should say Bose on the front of it, which means it will already have the amps under the rear parcel shelf ;)
Cumbria
Re: Bose amp
« Reply #6 on: 31 July 2008, 00:42:55 »
Checked does not say bose on front of unit. No bose amp fitted
markey mark
  • SLady bitshorpe north lincs
Re: Bose amp
« Reply #7 on: 31 July 2008, 02:06:13 »
only on elites was bose fitted !  :y
Re: Bose amp
« Reply #8 on: 31 July 2008, 08:32:47 »
Yes, Bose only on Elites.
You cna fit it but, get the loom and speakers to or its 'challenging'
You may have to cut the rear shelf to fit the bass units (if its a saloon)
You then need a little chat with Tech2 to put the radio in Bose mode.
Re: Bose amp
« Reply #9 on: 31 July 2008, 19:09:11 »
As MDTM says above - ccrt700 can be set to bose or non bose via tech2.
You will need the 6 main bose speakers, not sure about front tweeters, and the loom that runs down right side of car from kick panel to boot.
MutantCav
  • Gainsborough
Re: Bose amp
« Reply #10 on: 01 August 2008, 18:52:47 »
Unless you have an estate?? In which case the back setup is slightly different...
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Bose amp
« Reply #11 on: 01 August 2008, 22:21:52 »
Front tweeters are the same bose or no bose! fairly easy to do in all honesty just make sure you get the whole loom! as i didnt get enough loom so installed it underneath the passangers seat!!!
