Author Topic: getting CCR2006 out  (Read 2204 times)
rawsondsr
  • Near Dartford & Reading
getting CCR2006 out
« on: 12 August 2008, 16:22:37 »
i have the keys, i have inserted them, yet tugging doesnt do owt...
is there a knack?
Re: getting CCR2006 out
« Reply #1 on: 12 August 2008, 17:36:07 »
Same as any other using the double proned keys - insert with u ends slightly towards middle until they latch into place, then pull u ends outwards, and away from dash at same time.
If you've bent the retaining clip by inserting a prone the wrong side of clip, you may have a bit of trouble...
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 12 August 2008, 19:41:00 »
If you are wanting the aerial connector for the Harmon thingy, isn`t there a connector in the kickwell that you can break into without the need for removing the radio?
Others may be able to advise better than I can
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #3 on: 12 August 2008, 20:49:49 »
Indeed there is :y
rawsondsr
« Reply #4 on: 12 August 2008, 22:56:48 »
driver or passenger side?
« Reply #5 on: 13 August 2008, 17:46:26 »
drivers
