Author Topic: nokia car kit  (Read 5103 times)
jimmas
  • stevenage, herts
nokia car kit
« on: 31 July 2008, 12:28:52 »
Guys have a secondhand nokia car kit and cradle that supports the old nokia 6310 phone, my questions are as follows.
Am i right in believing my miggy is pre wired up behind the glovebox.
Were do most people mount the cradle and can this be done without drilling holes in trim, I only have the squre bracket with 4 holes in it to mount.
were do I get additional leads I think called autoleads from the use mic in interior lamp.
cheers
Re: nokia car kit
« Reply #1 on: 31 July 2008, 19:12:01 »
if you have cellular aerial on roof, prewired.  Mic won't be prewired, but thats easy (up passenger a post, along to sunroof panel, and mount around edge).
dashmount do a variety of 'no holes' brackets - expensive though.
sev
Re: nokia car kit
« Reply #2 on: 31 July 2008, 22:26:28 »
is the cellular ariel the one that looks really naff with the curly bit three quarters of the way down?
1995 2.5 V6 CDX Saloon
jimmas
  • stevenage, herts
Re: nokia car kit
« Reply #3 on: 31 July 2008, 22:49:00 »
the aerial on mine is a short stubby little thing, it's a 2.2i cdx on a 2000 plate
Re: nokia car kit
« Reply #4 on: 01 August 2008, 08:46:19 »
sounds like you need to remove glovebox to check for connector
master-sambo
  • Near Brands Hatch
Re: nokia car kit
« Reply #5 on: 02 August 2008, 12:07:08 »
Mine is wired up and goes under the centre console a bit.....i think i have a picture......
Not the clearest, but you can just about see where the wires go.
jimmas
  • stevenage, herts
Re: nokia car kit
« Reply #6 on: 02 August 2008, 15:48:19 »
thanks mate that picture does help me, I can see roughly were to mount it now, thanks to everone else for reply's
gazsomega
  • midlands
    • 2.5 Opel estate
Re: nokia car kit
« Reply #7 on: 13 August 2008, 20:32:31 »
i have in my the crt700 with the phone built in yet ive looked behind my dash and it also has a nokia kit but most the wires are cut so im lost with mine as i have one in my van thats nokia and is the same not sure if mines been fitted before me then removed or so on as i have no cradle in my car
Used  to have  two v6 and they roared
Now got 2.5 to Opel
Re: nokia car kit
« Reply #8 on: 13 August 2008, 20:34:14 »
Depends what kit it is, may be bluetooth?
sev
Re: nokia car kit
« Reply #9 on: 13 August 2008, 20:53:21 »
I have holes predrilled on the centre tunnel console shroud as in the photo above, so I guess that and the little ariel should mean that I've got mine prewired.
So all I've got to do now is get the handsfree kit!
is it possible to change the ariel to a beesting type?
gazsomega
  • midlands
    • 2.5 Opel estate
Re: nokia car kit
« Reply #10 on: 13 August 2008, 21:03:34 »
well i thought it would be bluetooth yet for it to be bluetooth doesnt it have to have a buton to turn it on which also turns the volume  my van one has a button to press to make it come on and connect
Now got 2.5 to Opel
