Author Topic: Drivers Door Speaker Fault  (Read 1780 times)
star_whites
  • Rotherham
« on: 29 August 2008, 22:27:01 »
I have a problem with my drivers door speakers not working. When you set stereo so that it is should be just drivers door working you can hear music very faintly. Is this down to an earth fault or is it possibl that the cables are damaged??
Re: Drivers Door Speaker Fault
« Reply #1 on: 29 August 2008, 22:38:35 »
could be the actual speaker....
star_whites
  • Rotherham
« Reply #2 on: 29 August 2008, 23:41:45 »
No, its definatly not the speaker as I removed a good one from the other door and tried that and it still didnt work.
« Reply #3 on: 30 August 2008, 09:32:37 »
OK, I had a similar issue.
Check wiring in door (if it comes adrift, it may be worn/crimped/broken/exposused if window has caught on it).
Next check the big multiconnector in the door for poor connections.
Next most likely is back of HU
Last connector is in drivers kickpanel.
