Author Topic: Dash bulbs - type and wattage?  (Read 8798 times)
JasonH
« on: 24 September 2008, 08:31:07 »
There's a picture of one in Useful Info, there's a list of bulbs in Technical Info but the one piece of info I need is missing....
What's the dash bulb type and wattage?
I'd rather not take the dash apart to get one out to take to the motor factors....
Tefal
  • herts
Re: Dash bulbs - type and wattage?
« Reply #1 on: 24 September 2008, 13:27:55 »
i'm doing a LED conversion possibly tomorrow so will have the bulbs to hand if no-one can answer for you
Welung666
« Reply #2 on: 24 September 2008, 13:40:12 »
Tefal, where did you get your LED's from? and how much?
Tefal
  • herts
« Reply #3 on: 24 September 2008, 14:27:20 »
Dazzler
  • Haverhill, Suffolk
« Reply #4 on: 24 September 2008, 16:08:54 »
They are the same as your side light bulbs but only 1.5w instead of 5w.
I assume your on about the ones that illuminate the speedo etc....??
JasonH
« Reply #5 on: 24 September 2008, 16:58:02 »
Actually it's the bulbs that light the warning lamps. I need to add the towbar flasher bulb.
Tefal
  • herts
« Reply #6 on: 24 September 2008, 17:08:35 »
that would be one of these then
JasonH
« Reply #7 on: 24 September 2008, 18:29:38 »
That's the one.
Now what's it called and what's the wattage - I don't want a sun tan from a warning bulb ;D
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #8 on: 24 September 2008, 21:42:18 »
ebay,
http://cgi.ebay.co.uk/VAUXHALL-OMEGA-GSI-V6-ELITE-TD-FULL-BLUE-LED-DASH-KIT_W0QQitemZ260287726145QQcmdZViewItem?hash=item260287726145&_trkparms=72%3A12%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
these are only plug n play ones for the dash and centre console. will be doing the headlight switch and push buttons at a later date
Shame they don't do a set for 2000-
Trade club card holder
Code scanner available
alexandjen
  • The Silver Surfer
« Reply #9 on: 24 September 2008, 22:47:45 »
ebay,
I asked the seller if he has a set for a 2000- Omega and he has replied saying that the above kit should fit fine :-/
Can anyone confirm please, thanks
Tefal
  • herts
« Reply #10 on: 25 September 2008, 09:02:45 »
mines a 2000 also, so will let you know the outcome. there are 12 leds bulbs in total
Tefal
  • herts
« Reply #11 on: 25 September 2008, 09:04:17 »
That's the one.
pm me your address and i'll send you a couple, i found some from when i did the my vectra conversion
« Last Edit: 25 September 2008, 09:04:34 by Tefal »
Tefal
  • herts
« Reply #12 on: 25 September 2008, 09:52:41 »
got the speedo out and have found there are two types.
1.1W and 2.0W. just depends on what bulb is needed for slot 12 HTH
Tefal
  • herts
« Reply #13 on: 25 September 2008, 11:25:35 »
it wont work on a 2000+
the kit i bought which is above listed is a waste of time
the four bulbs for the speedo are fine, but the ones for the TID dont show it up that well during the day and are green. so i'm gonna change them for some red ones as i know they will work.
i imagine that the climate control can be converted. will take a look at it when i convert the TC, Alarm, Boot Release etc buttons.
« Reply #14 on: 25 September 2008, 18:59:50 »
The Omega dash is designed to be lit up with incadescent bulbs, not LEDs, so LEDs aren't suited.  In particular, the gay blue ultrabrights end up with all switches dazzling you, and those using lightguides barely working.
