Author Topic: Fitting Telematics unit in boot  (Read 6656 times)
sev
Re: Fitting Telematics unit in boot
« Reply #15 on: 25 September 2008, 15:54:14 »
interesting.  What is the telematics, and how would you know if your car has it installed?
Is it anything to do with the phone prewiring? as I have the extra ariel on the roof, and the tunnel plastic has drill holes for what looks like a phone cradle of some description.
1995 2.5 V6 CDX Saloon
« Reply #16 on: 25 September 2008, 19:02:51 »
i would be most interested in the guide when done tb. Where you siteing it? In the old cd changer cuby hole?
I reckon I may just be able to squeeze telematics and CDC3 in to the BOSE amp shelf, hence not really 'wasting' the space so much.  Might need a spare shelf to practice on though.
That would free up the cubby hole for general junk, and obviously the space taken up with the Carin unit would be freed as well, as the Carin would no longer be needed...
« Reply #17 on: 25 September 2008, 19:04:52 »
No prefacelift has this type of telematics unit, facelifts only.  Some earlier cars had a phone option, but very rare.  ccrt700 had telematics in headunit (well, bolted on back).
Many Omegas are prewired, irrespective of telematics
sev
« Reply #18 on: 25 September 2008, 20:02:10 »
Thanks TB  :y
so what are the advantages of telematics as opposed to say the head unit with the sim card slot (don't know which one it is) or an install like a nokia?
I agree about the whole bluetooth thing, in that compatibility will always be a compromise, and of course the look of the car is going to get compromised with all the little screens and cables everywhere.
Mine has phone pre-wiring, but I take it that this is totally different to having a phone option?
« Reply #19 on: 25 September 2008, 20:56:45 »
Thanks TB  :y
No advantage over ccrt700 from phone point of view. Its just my chosen headunit has a seperate telematics rather than built in...
« Reply #20 on: 28 September 2008, 11:13:55 »
Pic of Mic and wiring.  3 wires, only 2 connected...
« Reply #21 on: 29 September 2008, 08:20:50 »
At first glance (I would need to check) that wiring looks different to mine as on mine the black wire (an extension of the cable shield) is connected to an un-used pin.....
« Reply #22 on: 29 September 2008, 08:31:32 »
The wiring on my bit of Mic loom (from a 1999 car fitted with CCRT700):
Pin1: Blue/Red
Pin2: Black (which looks like sheilding)
Pin3: Green/something
Ping4: N/C
As you can see, my mic is wired to pins 2 and 3.  Wiring diags suggest facelifts (or at least 2002 on) wired across 1 and 2.
Would this suggest a different mic?
« Reply #23 on: 29 September 2008, 08:36:05 »
Possibly
The above also shows that for a telematics setup that both pins of the mic are wired directly to the telematics unit without grounding any pins!
So ensure this is the case as a first port of call!
« Reply #24 on: 29 September 2008, 09:03:20 »
Possibly
To test, I have wired mic up to a short length (6") cable from telematics plug, using the signal pins 1 and 17.  Pin 2 of telematics (shielding) is disconnected.
At normal speech levels, remote party can't hear me if I'm more than 6" from Mic.
My mic is wired across pins 2 and 3 of mic connector, rather than 1 and 2, as my mic has no connection to pin 1.
« Last Edit: 29 September 2008, 09:04:22 by TheBoy »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #25 on: 29 September 2008, 10:19:54 »
Not sure if this helps or not, as unsure about vauxhall Mics, but in the aftermarket world there are many different types of phone mic, and although virtually all of them have the same 3.5mm jack plug, they often have different impedances resulting in different levels of voice - sounds like a similar problem you are experiencing by having to shout at the mic ?
Radio & Decoding Technician
www.dndservices.co.uk
