Author Topic: Brake Light Check  (Read 4546 times)
Richard P
  • Wimborne, Dorset
    • Mercedes C350
Brake Light Check
« on: 02 October 2008, 09:53:02 »
I have an intermittent problem with the brake lights on my 2.6 Elite. Occasionally the display come up with "Brake Light Check". When this occurs I find that the brake lights work perfectly, but when I turn on the lights the high level brake light also illuminates (although not as brightly as when the brake pedal is depressed). After a day or so the problem corrects itself. Anyone have any ideas as to what could be causing this?
Many thanks,
Richard.  :(
Re: Brake Light Check
« Reply #1 on: 02 October 2008, 10:44:39 »
As a first port of call, check the 0V connection in the boot, its on the passenger side behind the plastic slam panel trim.
Miggy24
  • Exeter,Devon
« Reply #2 on: 02 October 2008, 10:53:05 »
Also check your brake bulbs has i have a bmw e30 and the little on board computer was saying that my brake bulbs was out and they was working fine.Put 2 new bulbs in and it cured it :y
Richard P
  • Wimborne, Dorset
    • Mercedes C350
« Reply #3 on: 02 October 2008, 15:48:53 »
Thanks for the replies, I will try both suggestions and see what happens.
Thanks again,
Richard.  :)
markey mark
  • SLady bitshorpe north lincs
« Reply #4 on: 02 October 2008, 16:34:35 »
do you mean the earth connections mark !  :D
JueV6
  • Kent
« Reply #5 on: 02 October 2008, 17:28:11 »
I think that's the techie term markey, ment to confuse us laymen ;D ;D ;D ;D
Andyb
  • Lincoln
« Reply #6 on: 02 October 2008, 18:17:00 »
it has been known m8 that some times even though the bulbs are fine and work well
some makes will flash the warning up on the mid i would go to vauxhall and get bulbs from them and keep the ones u got as spares
« Reply #7 on: 02 October 2008, 18:22:05 »
Found Ring bulbs work ok for me - cheaper than VX.  Halfords bulbs can cause this problem.
Hi brake light on with lights is a dodgy earth.
« Last Edit: 02 October 2008, 18:23:02 by dbug »
« Reply #8 on: 02 October 2008, 19:23:41 »
 ;D  ;D  ;D  ;D
NB If you look in a Haynes manual for an Astra G you'll find the wirng diagrams are (useless but) laid out schematically(sp?) and you'll also find these everywhere in the book!  ::)
If you have a 'Positive Earth' car from the 50s & 60s obviously the postive terminal of the battery is connected to the chassis so ...... what would you call the negative terminal?  :-/  :-/ -12volts ??  :-/  :y
« Last Edit: 02 October 2008, 19:30:26 by Andy_B »
Richard P
  • Wimborne, Dorset
    • Mercedes C350
« Reply #9 on: 02 October 2008, 19:38:01 »
Went off to the local VX dealer this afternoon and bought a couple of new bulbs. Everything is now OK. I haven't checked the 0v connection as of yet but hopefully will get a chance tomorrow. Although all is now fine, I can't say for certain that the problem is cured as it's one of those annoying intermittent faults.
I guess only time will tell.
Thanks again for all the replies,
Richard.  :)
