Author Topic: fitting base box.  (Read 3478 times)
manny
  • bromorough.Wirral.
fitting base box.
« on: 09 October 2008, 23:15:34 »
Had a vibe evo 10 inch base box fitted in my last car and now want to fit it in my miggy.Dont want to fit a new head unit,I want to keep the standard vauxhall one.As this will not have the low inputs i will have to use the high inputs which the vibe evo has.Which speaker wires am i best cutting into?Fronts or rears?Thanks. :)
2001 OMEGA MV6
manny
Re: fitting base box.
« Reply #1 on: 09 October 2008, 23:30:38 »
Also is there a power source i can connect up to in the boot so i dont have to run a power cable from the battery.
2001 OMEGA MV6
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 09 October 2008, 23:34:47 »
I would advise to cut into the fronts as the volume of the rears can then be altered independantly.
I would also strongly advise to ONLY use the power feed direcly from the main battery via a fuse, don`t try to pick it up anywhere else.
Radio & Decoding Technician
www.dndservices.co.uk
manny
« Reply #3 on: 09 October 2008, 23:37:24 »
Thanks mate. :y
2001 OMEGA MV6
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« Reply #4 on: 10 October 2008, 14:19:47 »
Also make sure the feed from the battery is fused next to the battery (within atleast a couple of inches) alot of people make the mistake of fusing it at the amp end.
Also, if you drill through the bulkhead to pass the wire through, use a bit of paint to cover the metal, and then also a rubber grommet, so to help prevent cutting into the wire as time goes by.
Humbugs...
unlucky alf
  • worksop, notts
« Reply #5 on: 10 October 2008, 15:02:24 »
a while back i bought a converter to drop output down to 0.4w for amp purposes which connected to the back of the head unit, dont know if they are still available but it makes the job easier & tidier as you only need the rc cables as normal, the thing is i cant remember where i bought it :-/
murse
  • UK
  • Stressed
« Reply #6 on: 12 October 2008, 16:51:31 »
Something like this?
http://www.lowcostcaraudio.co.uk/lcca/4148/mia/d/autoleads+pc1+601+free+postage+2+channel+speaker+rca+adaptor/pid/7639852
More miles than the starship Enterprise but she keeps on rolling!  (Edit: not in a straight line anymore!)
unlucky alf
  • worksop, notts
« Reply #7 on: 13 October 2008, 00:43:01 »
same principle but mine was a bit bigger [little box thing], but i still cant remember where i got it from :-/
