Author Topic: adding tc button...  (Read 11256 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
adding tc button...
« on: 11 October 2008, 22:09:20 »
hiya, i bought a tc button (the one with large spacers to the left of it which is to the left of the radio)
i'v looked behind the stupid cubby hold and theres no wiring for the switch.
what do i do lol? i know i have to add the wiring but how and to where lol!
thanks
V8!!!!
Re: adding tc button...
« Reply #1 on: 11 October 2008, 22:16:01 »
all v6 should have the tc button anyway, only 4 cylinder and diesels dont
ngrainqey
  • rotherham
« Reply #2 on: 11 October 2008, 22:29:19 »
well mines a 2.0 16v so has the 4 pot body loom
which means that the tc button wiring could be under the 8? buttons above the radio but nothing seems to be to the right of the radio
V8!!!!
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
« Reply #3 on: 11 October 2008, 23:05:58 »
It's unlikly to have TC in the first place been a 2ltr 4 pot engine, chances are there will be no loom to plug into
ngrainqey
  • rotherham
« Reply #4 on: 11 October 2008, 23:27:45 »
what exactly would i have to do if i wanted wiring for it then? asin what would a have to have wires between. - i know i'd need a wire from the abs sensor/control unit and possibly the output shaft speed sensor on the gearbox but what else? ecu?
V8!!!!
JueV6
  • Kent
« Reply #5 on: 11 October 2008, 23:31:06 »
Think it's a look in the haynes book of lies. :y :y
ngrainqey
  • rotherham
« Reply #6 on: 11 October 2008, 23:33:46 »
lol i would but it doesnt say for example.. to add tc to the standard body ecu loom on a 2.0 prefacelift- you need: blah blah blah and then you splice such and such red wire from such and such relay from the ecu and connect it to such and such lol
they should make a how2 guide me thinks...
V8!!!!
« Reply #7 on: 12 October 2008, 08:29:45 »
You can't do it - the ABS ECU and Engine ECU do not have the capability.
MutantCav
  • Gainsborough
« Reply #8 on: 12 October 2008, 08:59:07 »
TB what about if hes upgraded the engine...would have thought the 2.5 ecu he has now would have the capability as the car its from had TC/ABS...so if the TC/ABS unit from a v6 was installed, would it be possible then?
« Reply #9 on: 12 October 2008, 09:08:10 »
Ah, misread.
The engine ecu has it.  The ABS ECU *may* be able to be reconfiged to have it, then its a case of following the wiring diagrams to ensure the wiring all there, I would imagine the wiring to be fairly simple.
Thinking about it, engine loom wiring would be there (as part of 2.5 loom), I imagine body loom for in cabin would have it anyway, so just need to check ABS loom...
MutantCav
  • Gainsborough
« Reply #10 on: 12 October 2008, 09:12:21 »
With his car being a 95...would the ABS/TC unit need to be out of an earlier model or would the later 98 onwards units work fine too??? As they are different I believe although not sure in what way, just obviously look different...
« Reply #11 on: 12 October 2008, 09:16:00 »
ABS would have to come from same era - ie, up to 1997, or 1998 onwards.
Not entirely sure if non TC ABS units can be programmed for TC, initial reaction is they can't
ngrainqey
  • rotherham
« Reply #12 on: 12 October 2008, 11:40:24 »
has anybody got a none tc abs unit and a tc abs unit and compare part numbers maybe?
might need one... and no probs for misreading "theboy"
i'v only really put that its now a 2.5 in my "drives" section
thanks
V8!!!!
« Reply #13 on: 12 October 2008, 11:49:18 »
UNIT, CONTROL, ABS (BOSCH 0273004042) 20SE, X20SE, X20XEV, U25TD, X25TD  -V1999999 90444661 12 37 644 1
UNIT, CONTROL, ABS (INCLUDES GASKET AND SCREWS) (BOSCH 1273004205) 20SE, X20SE, X20XEV, X20DTH, U25TD, X25TD W1000001- X1999999 9117173 62 37 699 1
UNIT, CONTROL, ABS (INCLUDES GASKET AND SCREWS) (BOSCH 1273004207) X20XEV, Y22XE, Z22XE, X20DTH, Y22DTH, X25TD Y1000001-  9192237 12 37 449 1
UNIT, CONTROL, ABS (BOSCH 0273004049) (NLS.- USE 90541367) X25XE, X30XE R1000001- V1006448 (90444662) (12 37 645) 1
UNIT, CONTROL, ABS (BOSCH 0273004170) X25XE, X30XE V1006449- V1999999 90541367 62 37 575 1
UNIT, CONTROL, ABS (BOSCH 1273004206) X25XE, X30XE W1000001-  9117171 62 37 698 1
« Reply #14 on: 12 October 2008, 11:50:58 »
So for 1995 with v6 engine, 90444662 or 90541367
1995 with non TC ABS unit, 90444661
