Author Topic: HID lights.Whats the difference?  (Read 4384 times)
manny
  • bromorough.Wirral.
« on: 15 October 2008, 22:19:11 »
Whats the difference between hid and projector head lights.They look the same from the outside.
2001 OMEGA MV6
JonArgraig
  • Isle of Angelsey
  • The Camera Ninja
Re: HID lights.Whats the difference?
« Reply #1 on: 15 October 2008, 22:23:50 »
HID Head lamps 6500k
Normal Foglamps
Full Beam
I have mini facelift projectors, the pictures where taken on a unlit road under 3/4 moonlight
« Last Edit: 15 October 2008, 22:24:25 by JonArgraig »
« Reply #2 on: 15 October 2008, 22:29:31 »
Projector lights still use incandecant lamps in them. HID are High Intensity Discharge & use a struck arc within the 'bulb' and use 35A
clicky
« Last Edit: 15 October 2008, 22:29:48 by Andy_B »
manny
« Reply #3 on: 15 October 2008, 22:36:50 »
The reason i ask is SEVS post about his head lamps look like HID,s but there not???
2001 OMEGA MV6
MutantCav
  • Gainsborough
« Reply #4 on: 15 October 2008, 22:39:54 »
Headlamp units look the same from the front...but different wiring, different connectors and a large silver box on the bottom with a thick wire running out of it to the HID bulb which is VERY different :)
manny
« Reply #5 on: 15 October 2008, 22:43:34 »
So just because its got that large looking bulb in it doesnt mean its HID?
2001 OMEGA MV6
« Reply #6 on: 15 October 2008, 22:53:48 »
That "bulb" is just actually a lens to shape the beam .. projectors and HIDS use the same lens ... so many folks confuse the two .. internaly the bulbs/wiring is very very different
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #7 on: 15 October 2008, 22:56:24 »
no thats just like a "projector" that magnifies the beam or some rubbish like that.
better than the horrible 94/5 headlamps that go yellow lol!
the hid lamps are just a projector unit with a ballast pack under which is actually a transformer or something similar and then has the high intensity discharge bulb in
V8!!!!
MutantCav
  • Gainsborough
« Reply #8 on: 15 October 2008, 23:12:10 »
Will try get a pic sorted of HID unit tomorrow mate so you can see the rather obvious differences :)
manny
« Reply #9 on: 15 October 2008, 23:12:18 »
Now i understand.Thanks lads :y
2001 OMEGA MV6
« Reply #10 on: 15 October 2008, 23:14:15 »
The differences are best observed from behind the steering wheel. You can actually see where yu're going with HID's :y
manny
« Reply #11 on: 15 October 2008, 23:22:39 »
In the vaux hand book it says that there only to be replaced by a stealer?Is that true or just a way of getting money out of your pocket? :)
2001 OMEGA MV6
murse
  • UK
  • Stressed
« Reply #12 on: 16 October 2008, 00:15:40 »
The 'dealer only' bit is due to much bigger voltages kicking about than in normal headlights.  As long as you know what you are doing (Haynes manual/FAQs) it is perfectly possible to do them yourself.
More miles than the starship Enterprise but she keeps on rolling!  (Edit: not in a straight line anymore!)
