Pages: 1 2 [3]  All   Go Down
Author Topic: HID foglights  (Read 9498 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: HID foglights
« Reply #30 on: 16 October 2008, 20:52:25 »
good news...
http://www.autobulbsdirect.co.uk
they do a hid foglight upgrade kit on there ;)
V8!!!!
Re: HID foglights
« Reply #31 on: 16 October 2008, 21:48:02 »
I very much doubt its a HID foglight bulb .... XENON perhaps ... :)
HID = High Intensity Discharge .. requires some seriously heavy duty wiring to handle the voltage to "strike" the gas discharge.
XENON = an inert gas used to fill the bulb so that a higher temperature can be obtained at the filament to give a brighter light
Ordinary bulbs can be replaced with XENON bulbs ... but HIDs are a different species !!
Unless you go to this page and pay out £200 - while the offer lasts .. usually £400 + !!!! !!
http://www.autobulbsdirect.co.uk/foglight-hid-system-c-699.html
« Last Edit: 16 October 2008, 21:49:41 by entwood »
ngrainqey
  • rotherham
Re: HID foglights
« Reply #32 on: 16 October 2008, 21:50:58 »
V8!!!!
amba
  • Medway towns
    • German V6
Re: HID foglights
« Reply #33 on: 17 October 2008, 19:55:10 »
Well after a bit of messing around I have now got a fully functioning set of HID foglights.The transformation from those old yellow things is truly amazing and the difference in appearance with low beam on is quite stunning..all I need now is to track down a set of decent side light bulbs (think I have done that courtesy of link provided by ngrainqey last night )and the old girl will look great.
The most confusing bit of all was that I had to reverse the wiring at the original plug end of the fog light loom as it seems that original lights are switcehd by an earth and you require a switched positive to get the ballast to fire up,but other than that not too hard a retro fit.
Anybody thinking of doing the same should be aware that on the mini facelift and assume pre 1998 you will need to extend the black housing on the back of the lamps as the HID bulbs are too long for the original unit..this I did with the aid of an aerosol can cap which fitted perfectly and keeps the water out,sealed on with some gaffer tape and then feed the new wires from the bulbs out the back.Bit tight getting the lamps back into their mountings but jobs all done and well pleased as total cost was less than £60=00 all in.
ngrainqey
  • rotherham
Re: HID foglights
« Reply #34 on: 18 October 2008, 17:48:03 »
lol well done matey ;)
hmm..."aerosol can caps" interesting! lol
V8!!!!
amba
  • Medway towns
    • German V6
Re: HID foglights
« Reply #35 on: 18 October 2008, 18:08:11 »
The plastic aerosol caps were an exact fit onto the back of the lamp body and being plastic made a water proof seal.The tape was then used to secure them and further aid sealing.The result is good and the light improvement is dramatic..well worth the fairly small outlay..almost a cheap as upgrade bulbs.
Pages: 1 2 [3]  All   Go Up
