Author Topic: ccrt 700 ilumination.  (Read 2836 times)
Cumbria
  • Southport. Merseyside.
« on: 22 October 2008, 18:06:35 »
Been offered bose ccrt 700 by a forum member. Illumination not working though. How easy is it to sort out. Thanks.
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: ccrt 700 ilumination.
« Reply #1 on: 22 October 2008, 18:13:57 »
can either be a shorted track or wiring problem...
If its the ribbon cable from board to front pcb, easy enough to replace.
if like mine its a duf track, just a case of closing the circuit up with some precise soldering.
Humbugs...
Cumbria
« Reply #2 on: 22 October 2008, 18:43:21 »
Was hoping it might be something simple like a  bulb or led. Ive got an old standerd ccrt 700 so might be able to swap bits over
PaulW
« Reply #3 on: 23 October 2008, 01:41:28 »
if your swapping bits, just replace the whole front panel (if the lights all work on the standard one)
If the standard CCRT700 you have works fine though, instead of going to the trouble of swapping bits just to get Bose, why not just Tech2 the current one to enable bose on that once all the wiring and amp is in place??
Humbugs...
Cumbria
« Reply #4 on: 23 October 2008, 02:15:11 »
Lights work fine on mine. Getting bose one at a good price. Probably works out cheaper than tech 2 plus petrol to take it plus the phone works on it. Only problem is doesnt light up.
« Reply #5 on: 26 October 2008, 10:29:02 »
Ah! I bet I know where thats coming from ;D
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 26 October 2008, 16:35:11 »
Your suspicions are correct  ;)
