Author Topic: ccr 2006 and sat nav  (Read 2198 times)
Edd
  • South Ockendon
« on: 12 November 2008, 22:25:24 »
Hi
Can the sat nav or colour display work with the ccr 2006 if so where is a good place to get one
If not what is a good recomendation for the front end
Cheers
Re: ccr 2006 and sat nav
« Reply #1 on: 12 November 2008, 22:28:41 »
Hi
Cheers
No.
« Reply #2 on: 12 November 2008, 22:29:49 »
CCR2006 will only work with MID or TID.  For CID or GID, you need NCDC range stereo. There are some wiring differences as well.
Edd
  • South Ockendon
« Reply #3 on: 12 November 2008, 22:38:11 »
Sorry im new here so I dont understand the abreviations. Can you explain them does this mean sat nav cannot be fitted to the existing system.
NickA
  • Cambridge
« Reply #4 on: 13 November 2008, 18:53:02 »
If you want to fit Sat Nav you need to replace both the ccr2006 and your current screen. That means a NCDC2013 / 2015 in replace if the ccr 2006 and a Colour Info Display (CID) instead of your Multi Info Display (MID).
I did this on my omega a few years ago a wrote up the procedure here:
http://home.btconnect.com/nickargue/OmegaSatNav.htm
It's do-able but quite expensive given the cost of Tom Tom etc.
« Last Edit: 13 November 2008, 18:53:21 by NickA »
Edd
  • South Ockendon
« Reply #5 on: 13 November 2008, 22:09:55 »
Thanks mate looks like Tom Tom may be better
