Author Topic: ncdc2015 + CID paired mv to new car diff engine  (Read 2534 times)
dpanic88
  • West Midlands
« on: 14 November 2008, 17:32:01 »
I now these units are getting very rare. I've got one - but its not working correctly. any way
have seen 2015 + CID from a 3.2 - (working units - but broken car )
question - can these paired be mv to new car which has a different engine. I know the fuel.. etc will be incorect
can it be set by (Tech2), after to match.
new car has pass code
unsure if orignal has pass codes.
sorry if this has already been asked in the past, I've had a search and look past older posts but not found answer
thanks for your time :)
Re: ncdc2015 + CID paired mv to new car diff engine
« Reply #1 on: 14 November 2008, 17:40:22 »
It will work as long as all parts are still present without playing with codes.
If you send the board out of the CD changer unit to Dave DND, he can tell you the pairing code used. Not sure what ne charges for that, as its slightly involved.  See http://www.omegaowners.com/forum/YaBB.pl?num=1223544723 for how we got this far.
Whats up with your old setup?
dpanic88
  • West Midlands
« Reply #2 on: 14 November 2008, 17:43:52 »
have a 2013 - cd autochanger is stuck and will not eject and the single top player will no longer  play anything.
radio works.
« Reply #3 on: 14 November 2008, 17:54:32 »
radio works.
What display do you have for your NCDC? And would you be interested in selling it?
dpanic88
  • West Midlands
« Reply #4 on: 14 November 2008, 17:59:55 »
have a CID, if I can get the other unit then I'll give you a shout.
« Reply #5 on: 14 November 2008, 19:10:50 »
Might be able to do you a deal on the Tech2 and decoding work ::)
