Author Topic: No fog lights  (Read 8259 times)
Martin_1962
No fog lights
« on: 16 November 2008, 19:37:14 »
Fuse OK bulbs look OK and light goes on on dash.
Rear fog lights do not work
What can I check please?
HotShot
  • Leeds, W Yorks
Re: No fog lights
« Reply #1 on: 16 November 2008, 19:55:32 »
Have you got a multi-meter / volt-meter to check if you have current?
Sounds silly, as you will me not be so silly, but, are you clicking the correct switch (front fogs = no light on dash while working, rear fogs = light on dash when working).
Also...do you have the headlights on & the engine running?
I think you need the headlights on before the rear fogs work.
Hope this helps.
« Last Edit: 16 November 2008, 19:56:32 by HotShot »
Re: No fog lights
« Reply #2 on: 16 November 2008, 21:00:23 »
There's a relay somewhere in the system to prevent you from leaving your fogs on for days ... & days  ... & days after the last bit of morning ,mist, you can hear it unlatch when you turn your lights/ignition off.
Martin_1962
Re: No fog lights
« Reply #3 on: 16 November 2008, 22:06:26 »
Trace down wiring - oh dear - I'll start with a relay hunt (where is it MDTM?) then down to wiring.
Correct switch - 8 years driving the things ;D
Re: No fog lights
« Reply #4 on: 16 November 2008, 23:13:58 »
It's not looped through the towing connector to disconnect the fogs when towing I suppose? Could be grot in the contacts in the socket?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: No fog lights
« Reply #5 on: 16 November 2008, 23:31:23 »
Worth swapping a fog bulb for an indicator bulb, just to check the bulb is ok ?
Do you have voltage at the bulb socket?
Radio & Decoding Technician
www.dndservices.co.uk
markey mark
  • SLady bitshorpe north lincs
Re: No fog lights
« Reply #6 on: 16 November 2008, 23:34:53 »
broken wire kevin near passenger side boot hinge ! :y
Martin_1962
Re: No fog lights
« Reply #7 on: 16 November 2008, 23:38:57 »
DOn't think so - but I have hit the towing connector on the ground last week
Martin_1962
Re: No fog lights
« Reply #8 on: 16 November 2008, 23:39:29 »
Swapped with reverse :(
Martin_1962
Re: No fog lights
« Reply #9 on: 16 November 2008, 23:39:57 »
Next thing is test tow fog - incase the hinge wire is gone
Martin_1962
Re: No fog lights
« Reply #10 on: 17 November 2008, 10:17:41 »
12S 12N undamaged
Should I hear a relay click?
Will try a multimeter across the 12S tonight to check the feed to boot
Re: No fog lights
« Reply #11 on: 17 November 2008, 10:35:41 »
The fogs normaly do route via the towing connector.....and the quality of the contacts on the towing connector is so piss poor its a wonder they ever work!
There is no relay for the rear fogs....but it does go via fuse F28
Re: No fog lights
« Reply #12 on: 17 November 2008, 12:06:43 »
I bet the vast majority of 12N sockets sold are those without the extra switch inside to turn off the car's fog lights.
What's that on track 1555/6 towards the top of Mr Haynes diagram?  :-/ It's not specifically labelled, but i think it's the main light switch
Something definitely makes a click in the light switch if you turn your lights off with the rear fogs still turned on.  ;)
Re: No fog lights
« Reply #13 on: 17 November 2008, 12:09:34 »
Agreed. I didn't bother, given that the probability of fog that I consider bad enough for a fog light is low, multiplied by the probablility of me towing....
Martin_1962
Re: No fog lights
« Reply #14 on: 17 November 2008, 13:51:10 »
I didn't remove that link either - but I'll pull out the connector during the week and check
