Author Topic: Completely dead key fob - what to do?  (Read 1731 times)
Martin_1962
« on: 28 November 2008, 19:21:11 »
Tried a good battery - no
Jumped a switch - no
All seems dead - what voltage do those little LEDs take - so I can check that it works?
If it does and the still doesn't work - what next
Tracks checked, through thingies checked
Re: Completely dead key fob - what to do?
« Reply #1 on: 29 November 2008, 00:04:28 »
Don't suppose you've got a scanner or similar that will tune to 433.92 MHz? You can hear them transmit if so.
Martin_1962
« Reply #2 on: 29 November 2008, 10:47:19 »
No scanner (unfortunately)
« Reply #3 on: 29 November 2008, 18:31:47 »
You can check the digital sender section with a scope.
Also, if its the early 2 button job then check the PCB very carefuly for cracks around the battery holder tags
