Author Topic: Want bose in my mv6  (Read 6004 times)
Martin_1962
Re: Want bose in my mv6
« Reply #15 on: 25 November 2008, 19:03:08 »
OH, forgot to put its a facelift if that maks any differance to the shelf.
You will have to cur the speaker holes, as post 1999 cars do not appear to have knockouts.  Also, you need the carpet bit of shelf with speaker grills
Did the Carlton tool wear out ;D ;D
MutantCav
  • Gainsborough
« Reply #16 on: 26 November 2008, 13:10:39 »
Its in the rear boot panel opposite side of where you find the cd changer and amp in the estate, could be a spare wheel there on the saloon?? :)
« Last Edit: 26 November 2008, 13:11:30 by ShieldOfSteel »
Tawfield
  • Berkshire
« Reply #17 on: 28 November 2008, 23:40:36 »
Ive just purchased a Omega Est 2.5 2000 V how do I confirm that it is a Bose system fitted to the car on the look around rear n/s cubby hole had a speaker behind the flap the o/s cubby hole was filled by a black box, what is confusing me is the on the dash panel are three press knobs same as the earlier model veh which control Bass Treble and stereo balance,the car Ive bought is still at the supplier dont pick it up till next week.
MutantCav
  • Gainsborough
« Reply #18 on: 29 November 2008, 21:12:32 »
Tawfield if its an elite then it should have Bose, does sound like you have the sub...check in the drivers side cubby hole, should be an amp in there as well as the CDC2 6 cd changer...
Tawfield
  • Berkshire
« Reply #19 on: 30 November 2008, 01:00:59 »
Thanks MuntantCav,
I will find out for sure once i collect the veh it is described as having a premium sound system.
