Help Philips Sat Nav Carin - Install & Wireing
Started by vauxsky, 06 December 2008, 02:41:45
vauxsky
#15
Can you put an image of your disks on this post page please, might help me get the right ones, map and firmware.
thanks
QuoteCan you put an image of your disks on this post page please, might help me get the right ones, map and firmware.
thanks
The map disk is the std yellow navteq type, nought descriptive on there, just the date and some copyright junk, plus navteq logo.  The firmware is silver (like the underside of the CD), with Philips, CARiN, SY581, and Version 2.3 written on it.
cbs2
A great place for the gps mouse.
Double sided tape it to the underside of the middle seatbelt cover on the parcel shelf. Keep it far enough back to miss the seatbelt & put the double sided onto the top of the ariel ( the non metal side)
Works a treat, gets full view, its hidden and you only need to run the cable into the boot corner
Taking part in the 2010 sucata split charity banger run. www.sucatasplit.com
www.boozebrothers2010.co.uk
Ex-mig owner................For now
QuoteA great place for the gps mouse.
The gps receivers I use (cheap off egay) have magnetic bases, so I pop them up through the hole in metal part of shelf, just above carin cd unit.  Even easier ;)
vauxsky
Ive just noticed that I dont seem to be recieving any GPS satalite signals, its at "0", I will move the arial into the open, but is this a problem.
Also the disk i have which is South East, when working appears to be out of position, even after I have  input the Car Position, I am concerned the signal from the car could be incorect, has this any bearing on the position.
thanks
QuoteIve just noticed that I dont seem to be recieving any GPS satalite signals, its at "0", I will move the arial into the open, but is this a problem.
thanks
Without the GPS, the accuracy will gradually drop out, so fix the GPS :y
If the reciever itself has failed, I use the ones from ebay for around a fiver (Allendale Stores or something I think is seller) - had around 3 or 4 from them, been excellent
