Author Topic: My mv6 with the 700 unit  (Read 13038 times)
Re: My mv6 with the 700 unit
« Reply #15 on: 08 January 2009, 21:54:49 »
Please.............do tell  :)
Need proper diagnostic equipment to be able to put a new software config on it, end user can't do it.
Christian
  • Shropshire
« Reply #16 on: 08 January 2009, 21:57:02 »
And what does this Software do to the Configuration?
What is the diffrence in overall sound quality  :)
Nope i dont doo Sheep!
« Reply #17 on: 08 January 2009, 22:19:35 »
the software config just flicks it between bose and non bose.  If you don't have bose amp and speakers, you can't run ccrt in bose config.
Christian
  • Shropshire
« Reply #18 on: 08 January 2009, 23:00:33 »
Ahh i got you, i think im gunna upgrade then if i have the 700 unit and look for Amp and shelf Woofers, i take it its as easy as plug and play with config?
« Reply #19 on: 09 January 2009, 09:32:07 »
Fairly easy to fit - you do need loom that runs along side of car though.  Additionally, you need to replace the door speakers with Bose ones.
You will need a parcel shelf from a Bose'd car (or cur yours yourself), and if its a 1999 or later car, you will need to drill the holes for the shelf speakers yourself.
Christian
  • Shropshire
« Reply #20 on: 09 January 2009, 09:52:05 »
The holes are there, but theres a plate attached over then from factory, looks to be spot welded but im sure its easy enough to do!
The loom you say is this from the head unit to the Amp?
benbrunt
  • Oldham
« Reply #21 on: 09 January 2009, 09:54:46 »
Can't speak for the non-Bose unit, but am more than happy with my current setup when playing cds. It's more than loud enough with no distortion whatsoever, not like the chavmobile drum n bass sounds you hear from some cars.
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
« Reply #22 on: 09 January 2009, 09:59:25 »
Not on 1999 and later cars - you have to get the drill out ;)
Christian
  • Shropshire
« Reply #23 on: 09 January 2009, 10:07:16 »
Am more than comatant enough to do that im sure!
The loom then, where does this go and what does it connect too, is it unit to Amplifier ?
Is the Amplifier just for the woofers?
Does the Bose front speakers just run from the Head unit or is this in connection to the Amp aswell?
« Reply #24 on: 09 January 2009, 10:23:31 »
loom from kick panel to amp/cd changer (cd changer loom is integrated, so you swap your cd changer loom for bose loom).
All speakers fed from amp, HU provides non standard Bose level signal to amp (via bose loom), and amped audio send back down bose loom to drivers kick panel, where it then goes off to doo speakers.
Christian
  • Shropshire
« Reply #25 on: 09 January 2009, 10:25:41 »
Ok so its a matter of just plugging in, then i take it configuration?
« Reply #26 on: 09 January 2009, 10:38:49 »
yup
Christian
  • Shropshire
« Reply #27 on: 09 January 2009, 20:48:02 »
Shweet , thanks guys!  ;)
