Author Topic: Easy fog light question  (Read 6466 times)
bighed
  • Shropshire
« on: 02 January 2009, 08:59:15 »
Have got a bulb out on one of my fog lights. What bulbs do they take and how do they come off to change bulbs  :-/
Welung666
Re: Easy fog light question
« Reply #1 on: 02 January 2009, 09:05:11 »
Bulbs are H1 and are fitted from behind, I jack up the front and slide under. Easy 5 min job :y
bighed
  • Shropshire
« Reply #2 on: 02 January 2009, 09:58:44 »
Thanks Wellung!!  :y
hotel21
  • The Kingdom of Fife
« Reply #3 on: 02 January 2009, 10:06:29 »
[movedhere] Omega General Help [move by] hotel21.
vauxfan2k
  • Western Isles
« Reply #4 on: 02 January 2009, 12:07:30 »
I find it far easier to remove the 3 torx screws for the plastic grille beside the fog, then remove the only screw holding the fog lamp in its mounting, lets you get the dust cap off easily and change the bulb.
cheers
« Last Edit: 02 January 2009, 12:07:45 by Vauxfan2k »
« Reply #5 on: 02 January 2009, 12:37:52 »
cheers
Not all bumpers allow you to use that method - but great if you can :y
blue_dream
  • Wellingborough
« Reply #6 on: 03 January 2009, 23:09:54 »
hi
    as already said, take the black plastic air vent off then unscrew lens, take care as the the screw may be corroded, good old wd40, same blub H 1 as main beam, if filled with water dry out with hot air gun  take care ;)
MutantCav
  • Gainsborough
« Reply #7 on: 04 January 2009, 17:20:00 »
Handy to know as one of my headlight bulbs has gone and I have dozens of foglights sitting around, saves me paying out lol
davlad22
  • Sunny Yorkshire
« Reply #8 on: 06 January 2009, 20:53:48 »
H3 fitment on facelift. Aren't preface the same???
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #9 on: 06 January 2009, 20:57:16 »
na the headlights and fogs are H1 main beams H7 on the prefacelift and i dont know about the fog lights on the facelift
« Last Edit: 06 January 2009, 20:57:43 by grainqey »
V8!!!!
Onkel Per
  • Frederikshavn - Denmark
« Reply #10 on: 09 January 2009, 22:54:02 »
It should be HB4 for the facelifted.
ngrainqey
  • rotherham
« Reply #11 on: 09 January 2009, 23:21:24 »
thanks!
hope they're called HB4's over here
« Last Edit: 09 January 2009, 23:21:45 by grainqey »
V8!!!!
« Reply #12 on: 10 January 2009, 08:51:53 »
thanks!
Yep they are.
Full Omega bulb details are here:
http://www.omegaowners.com/forum/YaBB.pl?num=1175644431/0#0
ngrainqey
  • rotherham
« Reply #13 on: 13 January 2009, 20:29:05 »
does have a pic of the HB4's mark :P
V8!!!!
« Reply #14 on: 13 January 2009, 21:42:44 »
Moan moan moan..... ;D
But fixed!
