Author Topic: cd player  (Read 8878 times)
vauxhallomega
cd player
« on: 04 December 2008, 11:23:07 »
hi all i cant get my crt700 set up to work , radio is ok but cant get the cd to run , just comes up with cd safe and cannot put in any codes thanks ricky  :(
markey mark
  • SLady bitshorpe north lincs
Re: cd player
« Reply #1 on: 04 December 2008, 11:33:43 »
press and hold the button with a o on it then switch on head unit then enter code when prompted then press the o button again and off you go  :y
vauxhallomega
Re: cd player
« Reply #2 on: 04 December 2008, 12:43:57 »
npoe tried all that, comes up cd code but wont allow me to put code in   :'(
markey mark
Re: cd player
« Reply #3 on: 04 December 2008, 12:46:09 »
sounds like its had wrong code in it then ! might have to leave it switched on for a good while to see if code input comes up !
does it just come up cd safe or do you get 10----  :-/
vauxhallomega
Re: cd player
« Reply #4 on: 04 December 2008, 12:51:35 »
just comes up cd-safe then when i press the buttons it comes up cd code but wont allow any input
markey mark
Re: cd player
« Reply #5 on: 04 December 2008, 12:53:59 »
get it to the cd safe part and leave it with ign on or running and wait bud to see if code input comes up ! should be a number 1/10 and 4 dashs ---- ! if nothing happens then changer has had code entered more than 10 times nad will need decoding by dnd  :(
vauxhallomega
Re: cd player
« Reply #6 on: 04 December 2008, 13:17:06 »
thanks , think i may need a  new unit
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: cd player
« Reply #7 on: 04 December 2008, 14:16:45 »
The word SAFE without a number to the left of it means that you are attempting to enter a code in the wrong sequence or your ignition is not on. If it is showing a number less than 10 and you cannot enter anything, leave both ignition and radio powered up for up to two hours or until another attempt is allowed as you have to allow the penalty time to reset after entering an incorrect code.
Radio & Decoding Technician
www.dndservices.co.uk
kmason8282
  • Southend
Re: cd player
« Reply #8 on: 21 December 2008, 21:13:20 »
I have a same/similar problem on a 98 Elite 2.5.
I have left the ignition on yet never get the prompt to enter in the CD code.  Is my cd player screwed?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: cd player
« Reply #9 on: 21 December 2008, 23:28:33 »
The prompt will only come up after the penalty time has elapsed (max 2 hours) and the correct button sequence is pressed to get to the code entry screen
Re: cd player
« Reply #10 on: 22 December 2008, 18:47:42 »
Vx documentation says up to 640m, which is nearly 11hrs...
kmason8282
  • Southend
Re: cd player
« Reply #11 on: 22 December 2008, 22:40:06 »
Gents, thanks for the replies.
Re the 640 mins is that 640min of the radio turned on all the time or 640 mins radio on/off etc.
last but not least is this a common issue with the cd players?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: cd player
« Reply #12 on: 22 December 2008, 23:08:42 »
Never seen that figure quoted before on a Vauxhall unit ?
Still, quite possible I suppose on such a high end unit.
But how are you supposed to leave unit and ignition powered up for 11 hours? I thought that one timed out and powered down long before that?
vauxhallomega
Re: cd player
« Reply #13 on: 23 December 2008, 14:46:19 »
dave my cd player is now reading  o cd safe  any help thanks
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: cd player
« Reply #14 on: 23 December 2008, 14:49:58 »
0-CD SAFE means that all of the ten attempts have been used up and the changer will have to be sent somewhere to be reset.
Which changer do you have? CDC2 Blaupunkt ?
